🔥Vente flash Alert! Premium Filaments from $9.49.Get Extra 10% OFF on 10+ Rolls
First modèle 3D: Tips for Beginner modèle 3Ders
First 3D Model: Tips for Beginner 3D Modelers - GEEETECH
vous've seen votre friend's imprimante 3D or really liked le imprimante 3D vous saw at work or school. So vous bought votre own... maintenant what? Every modèle 3Der has taken le same demanding path to get to le base of le 3D design. It seems like an adventure for personnes. Now, let us quickly look at le tips for beginner modèle 3Ders.
protodragon
To get excellent results in modèle 3Ding, vous must have passion. Therefore, tout related to computers, understanding, et le way objets sont placed in space et be an imaginative thinker.
Once vous get close to le modèle 3Ding hub; it opens windows to limitless opportunities. Le process est being used in various industries, from medicine to fashion, to engineering to entertainment. No matter le direction vous choisir to follow. modèle 3Ding va certainly turn out to be a idéal skill. Below est le information regarding le tips that beginner modèle 3Ders should follow.
Qu’est-ce que le modèle 3D?
A modèle 3D est a virtual representation of a three-dimensional object that est generated on a computer. It est a modèle that can be rotated et observed from all angles. A 3D file like ce est needed as input for a imprimante 3D.
https://youtu.be/OMpJYuGRHRA
About impression 3D a modèle 3D
Not all modèles 3D were created avec impression 3D in mind. Often, 3D files were created for animation movies or computer games, et typically, these models still devez to be prepared for impression 3D. There sont several design rules to keep in mind sur ce. But a very recurring issue est getting le adapté "wall thickness". Wall thickness est simply le distance between one surface of votre modèle et its opposite sheer surface.
Wall thickness 3d model
Start avec Modeling Simple Objects
Ce est like learning a new language: vous start by learning le alphabet, then different diphthongs, then short words, et then vous get to le tough part of putting them all together. Le same goes for modèle 3Ding.
3D Shapes
Start modeling simple objets, like cubes, spheres, et pyramids to become comfortable avec le basics. If vous don’t saurez le basics. Then, comment sont vous supposed to be successful avec plus complex shapes? Design simple objets until vous feel confident enough to move to plus difficult designs. Ce process va teach vous le correct approach et va construction le necessary modeling techniques to take votre work to le next level.
Know Your Printer’s Build Area
vous va devez to saurez le size of votre printer’s construction surface. To ensure le objets in votre design va fit when impression. Also, vous'll devez to saurez le size so vous can accurately cut a bigger modèle dans separate pièces. Thus, avoiding poor aesthetics et visible seams or lines après assembly.
If vous, however, want to modèle a larger part without le devez to cut it. Hence, keep in mind that vous can fabriquer use of le diagonal space. Experiment et find le solutions that va allow vous to modèle et print avec plus accuracy et precision.
Generating Gcode
Gcode est le code language that la plupart imprimante 3Ds run on. It's what tells them where to move, comment fast to move there, et comment hot to be.
To generate le Gcode vous devez, vous have several options:
  • vous can "Export" in le bottom adapté when vous're in le "3D View” or vous can go to "Layer View" et click "Generate."
  • "Generate" va completely slice votre modèle, but it va only save it in le backend of MatterControl, qui est helpful if vous aren't quite sure if le settings for votre print aren't adapté yet et don't want to fill up votre SD card.
  • "Export" va slice votre modèle et save it to a location of votre choosing.
  • Once le Gcode has been generated, if vous go to "Layer View" vous can view what each layer va look like avec either one layer at a time or in 3D et see le layer vous sont on et all le previous layers.
vous’re Ready to Get Printing! Wait - Ici Are Some Quick Tips:
  • Make sure le first layer est going down really well. If it's smearing, vous're too close; if vous can easily see where one line was laid down next to le other, vous're too far. vous have pour trouver that "Goldilocks spot."
  • Watch le first couple of layers. Le first layer may be fine, but le subsequent layer may have issues. Stick around for a little while to fabriquer sure tout goes smoothly.
  • Don't sit there for le whole print. Check up on it regularly, et be nearby, but vous don't devez to monitor it. Once we've tested printers avec short impressions, we can monitor while we sont in le office, et we va run weekend-long impressions on them without worry.
Conclusion
We hope these tips va help vous avec le information vous devez to start votre modèle 3Ding journey et support vous to keep going. Using these tips, beginner modèle 3Ders can enjoy impression 3D their own 3D objets.
Credits: Wings3D.com, youtube.
