🔥10 Rollen PLA schon ab 8,03 $/Rolle
3D-Druck-Ideen für Ostern 2025: Umweltfreundlich und praktisch
Easter is just around the corner, and for all 3D printer fans, that means new 3D printer projects can be tackled! But what can you actually print for Easter 2025 with a 3D printer?
We have some ideas for Easter 2025 for your 3D printer using an FDM printer!
These include Easter bunnies to print, 3D printing Easter eggs, and many other ideas for Easter 3D printing.
Easter Bunny
3D printing an Easter bunny is a popular printing object because it's a perfect gift and it's fun to print!
There are different versions. For example, you can make an Easter bunny with a basket or an Easter bunny that can carry a surprise egg on its back. There are no limits to creativity here. Start your 3D printing decoration project now and make your first Easter bunny 3D print.
Here are our hard facts for 3D printing an Easter bunny!
Printing Material: We recommend GEEETECH Rainbow filament, because the great color combinations really bring the Easter bunny to life!
Basically, you should use a PLA filament, as it is easy to print and allows for a detailed print.
Surface: PLA prints very smoothly and you get a very detailed print result. If you like, you can paint the surface, but if you use Geeetech Rainbow Filament, you already have a unique color combination.
Environmental Friendliness: PLA is a biodegradable material, as it is made from renewable resources. A perfect 3D printer filament for the popular Easter bunny.
Recommended Print Settings for Surprise Egg Easter Bunny (see image)
Print Bed Temperature: 50–60 °C
Extruder Temperature: 200–210 °C
Print Speed: 200–250 mm/s
Layer Height: 0.1–0.2 mm
Wall Thickness: 2–3 walls
Infill: 10–20 % (Rectangular or Hexagonal)
Support: Yes, „Touching build plate“
Fan Speed: 100 % (for PLA)
Adhesion: Brim or adhesive (if necessary)
Osterhase
Design by Karlss0n via Thingiverse
Settings for Easter Bunny with Basket (see image)
Material: PLA
Support: Yes, „Touching build plate“ (especially for the basket)
Osterhase mit Korb
Design by Wastl85 via Makerworld
3D Printing Easter Eggs
Besides printing the Easter bunny, 3D printing Easter eggs is always a great idea! You can easily make eggs as decorations for an Easter tree or as gifts for children to open! And, of course, no Easter egg hunt would be complete without eggs!
We have two versions for 3D printing Easter eggs for you.
Printing Material: PLA is perfect for 3D printing Easter eggs!
Surface: The printed surface quality is already very good and requires no post-processing.
Environmental Friendliness: PLA 3D filament is a biodegradable material and therefore very environmentally friendly.
Recommended Print Settings for Simple Eggs with Screw Cap:
Layer Height: 0.1–0.2 mm (for detail accuracy)
Infill: 10–20 % (for light structure)
Support: not necessary
These Easter eggs are very easy to print for Easter! A perfect activity for kids! If you have a kids' 3D printer, you can print the Easter eggs together for Easter 2025.
Design by LL-3D via Makerworld
Print Settings for Egg with Fire Truck
Layer Height: 0.1–0.2 mm (for fine details)
Infill: 10–20 % (for lightly structured parts)
Support: Yes, „Touching build plate“ (especially for overhangs)
Ostern kreative eier
Design by agepbiz via Thingiverse
Easter Basket
An Easter basket is a perfect Easter decoration for the home and at the same time perfect for storing small items. With a self-printed basket (filled with treats), Easter 2025 will be an unforgettable celebration, and printing the Easter basket and Easter bunny will be a lot of fun.
Printing Material: We recommend PETG, because it allows for easy printing and is a robust material, which makes the Easter basket a long-lasting object! If you want to know more about PETG printing, click here.
Surface: If you use PETG filament, you get a very fine surface when crafting the Easter basket. You can also decorate the Easter basket with paint!
Environmental Friendliness: PETG is not biodegradable, but it is recyclable!
Recommended Print Settings:
Print Bed Temperature: 70–80 °C
Extruder Temperature: 230–250 °C
Print Speed: 200–250 mm/s (slower than with PLA for better adhesion and surface quality)
Layer Height: 0.1–0.2 mm (for finer details)
Infill: 10–20 % (Hexagonal or Rectangular)
Support: Yes, „Touching build plate“ (especially with overhangs)
Fan Speed: 30–50 % (PETG does not require full fan speed like PLA to ensure good adhesion and surface)
Adhesion: Brim or adhesive (PETG adheres well to heated print beds, but if necessary, brim or an adhesive can improve adhesion)
Design by Slowpoke's Workshop via Makerworld
Easter Decoration
Easter is made special, among other things, by its Easter decorations! We have a 3D printed Easter bunny for the door and a spring bunny with a butterfly on a floral 3D decoration for you!
Easter Bunny for the Door
Printing Material: We recommend PLA filament!
Surface: The surface quality of PLA filament is very good and requires no or minimal post-processing. The Easter bunny can be decorated with colors if desired.
Environmental Friendliness: PLA is biodegradable and a perfect option for modern Easter decoration.
Osterhase für die Türe
Design by Enova 3D via Makerworld
Spring Bunny with Butterfly on Flower 3D Decoration
A very beautiful decorative piece is the bunny with flower decorations and butterflies! Perfect for any room.
Printing Material: We recommend PLA plastic filament
Surface: The surface quality is very good and requires only minimal finishing.
Environmental Friendliness: PLA is very environmentally friendly as it is biodegradable.
Unterstützung: Ja, „Touching build plate“ (besonders für Überhänge)
Lüftergeschwindigkeit: 100 % (für PLA)
Haftung: Brim oder Haftmittel (bei Bedarf)Frühlingshase mit Schmetterling auf Blumen-3D-Dekoration
Design von deLira über Makerworld
Oster-Nacht-Licht
Wer es an Ostern besonders gemütlich und kuschelig haben möchte, sollte sich dieses Design als 3D Druck Deko nicht entgehen lassen.
Druck-Material: Auch hier empfehlen wir PLA Filament!
Oberfläche: super Oberflächenqualität und kaum Nachbearbeitung nötig.
Umweltfreundlichkeit: sehr umweltfreundlich, da biologisch abbaubar.
Empfohlene Druckeinstellung:
Druckbetttemperatur: 50–60 °C
Extrudertemperatur: 200–210 °C
Druckgeschwindigkeit: 200–250 mm/s
Schichthöhe: 0,1–0,2 mm (für feine Details)
Wandstärke: 2–3 Wände
Infill: 10–20 % (für leicht strukturierte Teile)
Oster-Nacht-Licht
Design von NUKDDD über Makerworld
Outdoor-Ausrüstung
Mit Ostern fängt auch die Camping-Saison an! Der Frühling kommt und die ersten abenteuerlustigen Camper starten durch. Da sollte es an diesen zwei Objekten nicht fehlen.
Getränkehalter für Campingstühle
Druck-Material: Da der Getränkehalter für draußen gedacht ist, sollte man ein stabiles Material wählen. Wir empfehlen ABS Filament! Erfahre mehr zu ABS Druckeinstellungen hier, sodass du optimal drucken kannst.
Oberfläche: Da ABS relativ rau ist, ist hier die Nachbearbeitung der Oberfläche sehr wichtig.
Umweltfreundlichkeit: ABS Filament ist nicht biologisch abbaubar und nur schwer recycelbar und daher nur bedingt umweltfreundlich.
Druckbetttemperatur: 90–110 °C
Extrudertemperatur: 230–250 °C
Druckgeschwindigkeit: 40–50 mm/s (langsamer als PLA, um Warping zu vermeiden)
Schichthöhe: 0,1–0,2 mm (für bessere Detailgenauigkeit)
Infill: 20–30 % (Hexagonal oder Rechteck für zusätzliche Festigkeit)
Unterstützung: Ja, „Touching build plate“ (insbesondere für Überhänge und komplizierte Teile)
Lüftergeschwindigkeit: 0 % (ABS sollte ohne Lüfterdruck gedruckt werden, um Verzug zu vermeiden)
Haftung: Brim oder Raft (um Warping zu verhindern, vor allem bei größeren Druckteilen)
Wichtig: Du solltest eine gut beheizte Umgebung oder eine geschlossene Kammer verwenden, da ABS sehr empfindlich bei Temperaturschwankungen ist. Du solltest ein Absaugsystem nutzen, da ABS beim Druck Dämpfe freilässt.
Design von GNTZ über Makerworld
Befestigungsstifte (Zeltheringe)
Zu einer guten Campingausrüstung gehören hochwertige Zeltheringe! Drucke sie dir doch am besten einfach selbst!
Druck-Material: Wir empfehlen PETG oder ABS.
Oberfläche: Die Oberfläche ist eher rau. Wem eine glatte Oberfläche wichtig ist, muss das PETG oder ABS nachbearbeiten.
Umweltfreundlichkeit: PETG ist relativ umweltfreundlich, da es recycelbar und kaum toxisch ist. ABS ist nur bedingt umweltfreundlich, da es biologisch nicht abbaubar ist und nur schwer recycelbar ist.
0.12 mm Schichthöhe;
Es wird ohne Stützen gedruckt;
Sie können die Anzahl der Wände um 4 oder 5 erhöhen, um die Widerstandsfähigkeit des Teils zu steigern;
35 % oder mehr Füllmenge;
Befestigungsstifte
Design von 3D LayerBrothers über Makerworld
Fazit
Ostern ist eine perfekte Gelegenheit, neue 3D Drucker Projekte zu starten. Es gibt viele Möglichkeiten, Osterdeko zu drucken und Ostern 2025 zu einem unvergesslichen Fest zu machen.
Wir haben ein paar Deko-Ideen für euch zusammengefasst und 3D Drucker Projekte vorgestellt, die man perfekt mit Kindern machen kann. Auch haben wir ein paar einzigartige Objekte für das Camping hinzugefügt, denn mit Ostern beginnt auch die Campingsaison.
Hinterlasse einen Kommentar
Bitte beachte, dass Kommentare vor der Veröffentlichung freigegeben werden müssen.
