A pen that lives up to your creativity, not only on paper but in the 3-dimensional world! Hard to believe, but true. With a 3D pen, you can design objects, small toys, and creations individually.
All you need is 3D printer filament and a 3D pen.
We have summarized all the essential basic information for you here, so you can start printing with your 3D pen in no time.
Let's get started!
What is a 3D pen?
A 3D pen is essentially the handy mini version of a 3D printer. The 3D pen uses a filament, which is heated and then extruded from the pen tip. The soft filament cools down immediately, allowing for relatively precise 3D printing. One could compare the filament of 3D pens to the ink of a regular pen, but with the special effect that you can draw not only on paper but also in space.
How to use a 3D pen?
A 3D pen is much easier to use than a 3D printer. For example, you don't need any software and thus no computer skills.
You can start printing with a 3D pen starter kit in just a few minutes. Basically, various 3D print filaments can be used. Popular choices are PLA filament, ABS filament, and PCL filament.
You should follow these steps:
- Press the power button
- Select the filament you are using on the screen (for example, PLA 3D Filament)
- Press the "Load Filament" button to preheat the 3D pen (red LED will be displayed)
- Once the light is green, press "Load Filament" again so that the filament is transported into the nozzle.
- Now you can print! You can adjust the temperature and speed while printing.
- Make sure you use all the filament and no residue is left in the 3D pen. To do this, use the "Unload Filament" button (hold the button for 3 seconds)
Here are a few important tips you should keep in mind:
- The print tip is hot, avoid skin contact
- Avoid contact with water (electric shock)
- Unplug the power cord immediately after use
- The 3D pen is suitable for adults and children aged 5 and over
- After one hour of use, a 15-minute break should be taken
If you use Geeetech Filament, you can follow the temperature and speed recommendations in the instructions. If you use a different 3D printer filament, you should follow the manufacturer's information.
Common 3D pen problems and their solutions
We have summarized the most common problems and their solutions for you:
- Filament is not extruding
Possible problems: Nozzle clogged, filament incorrectly inserted. Temperature too low
Solution: Clean nozzle with cleaning needle, insert filament correctly, adjust temperature according to filament
- Filament jams inside
Possible problems: Filament retraction at low temperature, abrasion due to frequent direction changes
Solutions: Bring device to operating temperature before changing filament, clean regularly
- Irregular flow and clumps
Possible problems: Contaminated/damp filament, incorrect printing speed
Solutions: Use high-quality filament, adjust speed
- Nozzle overheats or remains cold
Possible problems: Defective heating element/temperature sensor, unstable power supply
Solutions: Check power supply, reset device and, if necessary, have it professionally serviced
- Filament stuck in the pen
Possible problems: Changing at too low a temperature, filament removed quickly/forcefully
Solutions: Heat the pen and carefully retract the filament, use cleaning filament if necessary
Whether it's a 3D pen for children or used by beginners; most problems can be solved independently, so that printing can be done without major challenges.
What can you do with a 3D pen?
Here we clarify the question: "What can you do with a 3D pen?". 3D pens are very uncomplicated to use and require neither technical nor software-related knowledge. If you follow the manufacturer's recommendations, you can turn any idea into reality with a 3D pen.
Here are a few examples:
- Creative design: Freehand drawings, decorations, works of art
- DIY & Craft projects: Jewelry, personalized gifts, models and miniatures, toys
- Repairs and functional items: Repair plastic parts, reproduce parts, repair surfaces
- Learning and education: Promote technical understanding through models, school projects, promote motor skills and concentration
There are printable 3D pen templates, various 3D pen templates and 3D pen ideas that can be used as inspiration and guidance. This makes the 3D pen a great tool for children and beginners to get started in the world of 3D printing.
For first attempts at 3D printing, it is advisable to make simple drawings to slowly get used to the pen's behavior and understand the printing principles. Once you are confident in using a 3D pen, you can venture into more complex objects and 3D pen ideas.
For children and beginners, templates are a great help, as they allow them to gain their first 3D printing experience. There is a wide selection of printable 3D pen templates that implement great 3D pen ideas and offer good practice material.
3D pens are not just a toy. They are a tool that promotes children's creativity and problem-solving skills. Spatial design creates a deep understanding of shapes and constructions. Drawing in 3D with the 3D pen promotes spatial thinking and allows children to fully express their creativity. They can individually and independently realize their own ideas in various shapes and colors, as well as in different sizes. Drawing with a 3D pen strengthens the ability to approach challenges with creativity.
Conclusion
3D pens are a comprehensive tool with which children can fully unleash their creativity.
No prior knowledge is required, and with a 3D pen starter kit, you can immediately create first shapes and drawings without extensive preparation. A variety of templates are available to facilitate entry into using the 3D pen.
In addition to the objects created, using the 3D pen promotes children's intellect. Problem-solving skills are developed, creativity is fostered, and spatial thinking and understanding are strengthened.
