ABS-Like Resin in 3D Printing
Geeetech ABS-Like Resin
3D Printer resin is a key material used in a specific type of 3D printing technology called stereolithography (SLA) and digital light processing (DLP). The main technology in them is to cure and form liquid resin into hard models under ultraviolet (UV) light exposure.
3D printing technology first originated in the 1970s, when it was mainly used to create prototypes. In 1983, Chuck Hull from the USA invented stereolithography (SLA) and in 1986 he co-founded the world’s first 3D printing company which was a great process for 3d printing development. Nowadays, it is frequently to use resin in 3d printing. Here is the timeline related to resin 3d printing:
history of resin 3d printing
What is ABS-Like Resin?
ABS-Like Resin is a photopolymer resin that is widely used for DLP or LCD 3D printers. ABS-Like resin contains high-quality pigments and photoinitiators which empower 3d prints with bright and stunning colors. As its similarity to ABS, it performs well in printing functional or mechanical accessories. It’s a nice choice for printing regular 3d models with smooth and exquisite appearances.
Main features of Geeetech ABS-Like Resin:
  • Compatibility: Our ABS-like resin works seamlessly with various LCD and DLP printers. It is designed for broad market applicability, ensuring it pairs well with LCD and DLP technology printers.
  • Fast Curing & High Efficiency: It boasts a rapid curing time, which significantly boosts the success rate and overall printing efficiency. For optimal results, it is recommended to set the exposure time within the resin printer to either 1.7s or 2s. Moreover, it’s safe, non-toxic, and emits minimal odor.
  • Precision & Quality: It exhibits excellent fluidity and high precision with minimal shrinkage, leading to clear and detailed prints. This makes it ideal for both novices and seasoned 3D printing aficionados.
  • Secure Packaging: It comes in safely and thoughtfully designed packaging, featuring a leak-proof design to prevent spills during transport.
What are the differences between standard resin and abs-like resin in 3d printing material?
Standard resin and ABS-like resin are two different types of materials used by 3D resin printers each with its own set of properties and characteristics. Here are the key differences between standard resin and ABS-like resin:
Material Composition
  • Standard Resin: typically, standard resin is a photopolymer resin that cures when exposed to ultraviolet (UV) light during the 3D printing process. It is well known for its smooth surface finish and high level of detail.
  • ABS-Like Resin: ABS-like resin is formulated to mimic the properties of Acrylonitrile Butadiene Styrene (ABS), a commonly used thermoplastic in traditional manufacturing. ABS-like resin is used for functional prototypes and end-use parts quite a lot.
Flexibility
  • Standard Resin: standard resin is generally less flexible and more rigid. It might not perform well during the 3d printing process which requires a certain level of flexibility or elasticity.
  • ABS-Like Resin: ABS-like resin can exhibit better flexibility and is more resilient to bending and deformation. This makes it a preferred choice for functional prototypes that would bring challenges to some degree of mechanical stress.
Post-Processing
  • Standard Resin: standard resin usually requires less post-processing compared to ABS-like resin. It may not need extra procedures like vapor smoothing or extensive sanding.
  • ABS-Like Resin: ABS-like resin might benefit from post-processing techniques such as vapor smoothing to improve the surface finish and appearance. This is especially relevant for parts that require a more polished look.
When choosing between standard resin and ABS-like resin, it’s essential to consider the specific requirements of your 3D printing project, including mechanical properties, flexibility, and intended applications. Each type of resin has its advantages, and the selection should be based on the desired characteristics of the final printed object.
Leave a comment
