Here are 5 Useful Things You Can Make Right Now With Your 3D Printer!
Here are 5 Useful Things You Can Make Right Now With Your 3D Printer! - GEEETECH
Amidst all the cool artwork and industrial designs, all we really want to do is 3D print some cool objects to use in our daily lives. Especially if you're a hobbyist or beginner. So take a look at some useful things that you can make with your 3D printer!
1. Earphone Holder
3D Printed Earphone Holder
You may put your earphones in your pocket as gently as you can manage, but eventually, they will end up in a tangled mess ( just like always ). Luckily, this cool earphone case is here to make life much easier and you can find it on Thingiverse!
You can use either clear PET filament for the first couple of layers since it works better as a hinge material and works as a window, but ABS filaments will work too. They take around 30 minutes to print.
Find it here.
2. Wall Outlet Shelf
3D Printed Wall Outlet Shelf
Not everyone has super long charging cables or wall outlets conveniently placed next to them. That’s where this wall outlet shelf comes in handy. Leave your phone to charge or prop it up to watch videos! The possibilities are endless. Its angled design holds the phone or tablet in an upright viewing position!
What’s even better? This shelf can be used either vertically or horizontally.
Download from here.
3. One-Handed Page Holder
3D Printed Page Holder
3D Printed Pages Holder
How many times were you left frustrated while trying to keep a book open with just one hand? Well, here is something that will make your life a little easier. You can hold your book wide open with your thumb!
A simple but ingenious life hack for those who like to read good old-fashioned books. This one-handed page holder is very easy to print and it fits aptly in the hand.
And if you’ve got a bigger thumb you can simply scale the model up slightly in your slicer!
PLA filaments are recommended.
Get it here.
4. Toothpaste Tube Squeezer
3D Printed Toothpaste Tube Squeezer
Yes, it’s just a simple toothpaste squeezer, but it saves you money by ensuring you get the most out of your tube. Kudos to whoever came up with this idea!
You can print it in 3 parts. The cap can be securely pressed or glued onto the shaft. Printing it as a solid object is most advisable. It’s presumably wide enough to accommodate all toothpaste tubes yet fits comfortably in the hand. The latest has a lock feature to prevent the tube from unrolling. All you need to do is press the shaft inward to engage the lock and pull out to disengage.
Download from here.
5. IPhone Dock & Amplifier
3D Printed iPhone Dock & Amplifier
This exclusive design for the iPhone is pretty nifty. It acts as a passive amplifier horn to amplify your phone’s speaker without power. Not too shabby. You are likely to find other designs to fit other phones. Based on a Western Electric exponential horn, it is 7.5″  in length and press fits into the base of the iPhone. This quirky accessory is sure to make heads turn!
Find it here.
Credits- Thingiverse, all3dp.com
Leave a comment
