It is well known that there are 3 kinds of light-curing 3D Printers in the market, they are SLA, DLP, and LCD light-curing machines. Alkaid 3D Printer belongs to LCD light curing machine. It’s easy to operate and assemble.
Introduction to the Alkaid 3D Printer
1) High precision. ALKAlD features a 6.08-inch monochrome LCD with 2K HD definition, enabling X/Y accuracy up to 0.05mm.
2) Premume printing quality. Its z-axis uses a high-cost linear guide rail, which has the characteristics of high rigidity, high load, automatic self-aligning, absorbing assembly errors, etc., which can effectively improve the overall printing quality of 3D printers.
3) New matrix UV light source. The matrix light source uses 15 pieces of high-light power quartz lamp beads, with professional optical materials made of the matrix lens, so that ultraviolet irradiation on the LCD screen is more uniform, and higher intensity, effectively improving the printing speed and accuracy.
4) High-efficiency cooling system. The rugged Alkaid innovates by integrating UV lamp beads on the aluminum substrate at the bottom of the machine, allowing for a greater heat dissipation area. With the cooling fan, it can effectively reduce the temperature of the lamp board and extend the service life of the UV lamp beads.
5) Professional UV-blocking cover. Alkaid transparent cover contains anti-UV element, which can effectively filter UV light of 405nm wavelength, and the blocking rate is up to 99.96%. The cover can not only ensure the printer’s UV light does not leak but also ensure the external UV light does not affect the printer’s normal work.
6) User Friendly. Alkaid is easy to operate and affordable, making it ideal for beginners and amateurs and one of the best 3d resin printers. In addition, Geeetech can provide ODM and OEM custom design and manufacturing.
ALKAID LCD 3D PRINTER
- 6.08″2K Resolution. With high precision and fast printing speed, it can bring you high-level detailed printed models.
- Premium Linear Guide Rail. It has outstanding features of high rigidity, high load, and automatic self-aligning.
- New Matrix Light Source. 15 high-power quartz UV lamp beads with the combined matrix lens contribute to more uniform and higher intensity UV light.
Skills and experience in maintaining printers are important, we all start from beginners to masters. As time passes by you will find that you are excellent at maintaining printers and have lots of experience for sharing.
Guidance of operation and maintenance.
How to replace UV Light: The following is a video tutorial to replace the UV lamp, please follow the tutorial.
For motherboard replacement: The following is a video tutorial to replace the motherboard, please follow the tutorial. purchase link Alkaid resin 3d printer motherboard.
Replacement for FEP Film: First please prepare a sheet of Alkaid FEP film and install the new FEP film.
If the pressure plate is damaged, please refer to the following advice. Here’s the pressure plate purchase link.
The rupture of the pressure plate will cause the resin in the resin box to leak onto the printing screen, and the resin is corrosive and likely to corrode the printing screen. When replacing the FEP film, please be careful not to use too much force, just make sure that the screw is screwed properly, if too much force will cause the pressure plate to crack.
Useful submit! I really want this sort of article.. that is very beneficial for me.
Thanks! Enjoy your weekend 🙂
Yes, exactly.
Comments are closed.
