I have a problem with my Geeetech E180 printer. During the printing process, the printer pauses automatically. This process must then be continued manually. These breaks occur at irregular intervalls.
Does anyone know what to do there?
Printing Pause
Re: Printing Pause
Could you upload the G-code files?
Re: Printing Pause
How can I upload the files?
Re: Printing Pause
You can upload it to the Google drive and then attach the link to the post
Re: Printing Pause
same here! Printer paused, but only when connected and printing from the PC.
I'am saving the same gcode file onto SD-Card, and printing from sd-card is perfect without pausing.
Re: Printing Pause
It is not a mistake from gcode, it is possible that is a mistake into the firmware.
I've triad a lot the last few days with printing pause.
With EasyPrint3D the print paused irregular, but with Repetier i found this:
The print start and the nozzle - fan working between 50 and 100%. After 30 minutes, the nozzle fan going suddenly to full speed 100% and the printing stop immediately. You can't do anything, the touch doesn't response and click paused in Repetier didn't do anything.
ONLY if you set down the fan speed in repetier with the slicer from 100% to 90%, the printing goes on.
Re: Printing Pause
Could you tell us the firmware version of your printer?MichaelK wrote: ↑Wed Mar 28, 2018 12:58 amIt is not a mistake from gcode, it is possible that is a mistake into the firmware.
Re: Printing Pause
Of course: the display onto my E180 tell me: Version: 1.23.25 and Repetier Version 1.1.0 on macOS said: 1.0.25
Re: Printing Pause
Same problem and I do not find the solution I have tried everything possible the printer pauses several times during a print and you have to manually start it every time impossible to use in this way
