A10 Freakout
Jarda3d
Re: A10 Freakout
Post by Jarda3d » Mon Sep 23, 2019 7:35 am
Probably bed is not flat. Get my A10 profile and when it does circle about object, you can fine.tune bed level.
From front side view of bed knobs:
turn ===> to make bed low
turn <==== to make bed high
One whole turn is 0.5mm.
A10 Slic3r profile: here
wotor
Re: A10 Freakout
Post by wotor » Mon Sep 23, 2019 8:14 am
You can also check Y axis wheels, if you can move your bed left and right or up and down, they need to be adjusted. If they loose bed leveling will be compromised.
Re: A10 Freakout
Post by William » Mon Sep 23, 2019 9:43 am
Hi,For nozzle clogging cleaning you can refer to this: http://www.geeetech.com/forum/viewtopic ... 98&t=68671
Regarding the hot bed problem you can remove it to see if it is level.
