Cura profile file for A30T
rotormansa
Post by rotormansa » Thu Mar 04, 2021 5:01 am
Is there profiles for Cura? I have the profiles for repetier but in some cases Cura would nice.
MOCCOR
Re: Cura profile file for A30T
Post by MOCCOR » Fri Mar 12, 2021 7:14 am
Geeetech is very good for organization, this is right on their homepage under the downloads tab and then "Cura configuration file" - https://www.geeetech.com/download.html?download_id=47
rotormansa
Post by rotormansa » Mon Mar 15, 2021 5:38 am
Thanks for this.
where do the A30T.curaprofile and A30_PrimeTower.curaprofile files go or how do you install them?
Guizmogwaii
Post by Guizmogwaii » Tue Mar 16, 2021 8:48 pm
Just copy and past the folders in the same cura folders.
Then you will have the A30t in the printer liste of cura
rotormansa
Post by rotormansa » Wed Mar 17, 2021 5:38 am
Can't copy the curaprofile files to any Cura location, these must be imported via the Cura tool. I figured it out after doing some google searches.
fasteddy13
Post by fasteddy13 » Mon Mar 22, 2021 5:29 pm
Anyone know how to get the A30T to appear on the drop down list of printers? I have imported the profile files ok, but cant see the A30T in the printers section. Is a json file required?
Guizmogwaii
Post by Guizmogwaii » Mon Mar 22, 2021 6:46 pm
Vous chercher trop compliquer...
Je l'ai encore fait ce week-end sur mon 2eme pc ....
Installation de cura ensuite il faut juste copier les fichiers des 3 dossiers dans les mêmes dossiers de cura.
Rien à importer juste copier
Guizmogwaii
ozcanroy
Post by ozcanroy » Tue Mar 22, 2022 7:41 pm
MOCCOR
Post by MOCCOR » Thu Mar 24, 2022 12:58 am
It won't, I'm not sure how it is decided how those printers get added. But you can select the A20T and then edit the A30T info into it and rename it.
