Problem with Aluminium Prusa I3 assembly
Brisruss
Post by Brisruss » Fri Apr 21, 2017 3:30 pm
I have a problem where the rods for the extruder assembly seem too be too tight. They did not fit in the x-axis end caps. The linear bearings are also tight on the round bars and will not move freely.
The horizontal bars seem to be 5/16 whereas the vertical bars are 8 mm. How do I fix it?
Thanks,
Russ
Newopint95
Re: Problem with Aluminium Prusa I3 assembly
Post by Newopint95 » Sat Jun 24, 2017 1:28 am
I used the file to enlarge the holes until the rod just fit. I also took the time to lube the bearings and run them over the rod to get them moving smoothly.
