I am trying to follow instructions on how to connect the 3DTouch to the board of the geeetech pro c GT 2560.
Everywhere it say to connect the 3 pin connector to the z-max ( the board have only 2 pins on z max )
anyone done that already ?
3DTouch auto level connect to pro c GT2560
Re: 3DTouch auto level connect to pro c GT2560
You will need to unsolder the 2 pin connector and solder in the 3 pin terminal block included with the 3D touch. There are actually 3 holes under that 2 pin connector.
Someone mentioned there may be a way around having to do this, but I've never seen the instructions on how to do it.
Oh Darn
I will not do this i will probably damage the board.
If someone know a way that it could be done without soldering, it would be amazing.
Thank you
Thank you
hEY i JUST SAW YOU POST YOU BOARD if IS SAME that MY ONE WITH BLUE CONNECTOR if , they move the 3 pin down to the left side of the board hat one is for touch sensor.
Ah, there's a new version of the board out in the store. It must have come out after I ordered my Pro c last fall.
this one is the one I have, I still working on the firmware to make it work, do you have any lik for this the one that I have is kind confusing.
- GT2560 look the new one.
- Geeetech_20170116194208.jpg (53.54 KiB) Viewed 9106 times
