Assembly manual of Hexypider— the Hexapod
In my last post, i have introduced the Hexypider for you and some are asking for the assembly manual, ok, let’s check together.
we will take one leg firsto assemble , let’s have a look at the parts needed.
1, the main body of the robot is two pieces of acrylic plate.
Part 1: acrylic sheet on the bottom x 1
Part 2: acrylic sheet on the top x 1
step1 _meitu_1
2,The hardware needed to assemble the HexapodT1GCq1XnXqXXb5t478_101021.jpg_310x310_meitu_4
Part3: brass straight pin M3 40mm x 5
Part4: sink head screw M5 10mm x 6
Part5: round head screw M3 12mm x 6
Part6: round head screw M3 10mm x 34
Part7: round head screwM1.5 11mm x 18
Part8: round head screwM2 7mm x24
Part9: screw nut M5 x 6
Part10: screw nut M3 x 34
Part11: screw nut M1.5 x 18
Part12: Servo fittings x 12
Part13: self tapping screw M2 9mm x 6 (with washer)
step2 _meitu_2
3 ,Other acrylic supporting components
 Part 14:Acrylic fitting x 6
Part 15:Acrylic fitting x 6
Part 16:Acrylic fitting x 6
Part 17:Acrylic fitting x 6
Part 18:Acrylic fitting x 3(on the top)
Part 19:Acrylic fitting x 6
Part 20:Acrylic fitting x 6
Part 21:Acrylic fitting x 6
step3 _meitu_5
Ok , now we can move on to the  assembly procedure
Step 1
Take the part 13; fix the Servo in part 13 with a screw (part7) and screw nut (part11), as shown in the picture;
step4 _meitu_6
Step 2
Take out part14 and 15, mount them in to part 13(plug slightly, do not force too much, or the acrylic part will be broken.) as shown in the picture;
step5 _meitu_7
Step 3
Take out another servo; thread the wire of servo through the hole on part 13.
step6 _meitu_8
Step 4
Fix the servo on part 13with a pair of screw (part 7) and screw nut (part 11).
7_meitu_21
Step 5
Insert part 12 into part 19.
step8 _meitu_10
Step 6
Screw up part 12 and 19 with a round head screw (part8),
step9 _meitu_11
Step 7
Take out part 20 and 18; screw up part 20 and the assembled part in the above step on part 18 with two round head screws (part 6).
step10 _meitu_12
Step 8
Tighten the part finished in step 7 up on the part finished in step 4.
step11 _meitu_13
Step 9
Block up the rocker arm with part 16; screw it up with part 10 and 11, assemble the rest arms in the same way.
step12 _meitu_14
Step 10
Tighten part 17 up on part 2 with a pair of screw and screw nut (part 6). Assemble the rest 2 part 17 on the acrylic sheet in the same way.
step13 _meitu_15
Step 11
Insert the white part (the servo fittings) into the following place. Screw them up with a round head screw (part 8).
step14 _meitu_16
Step 12
Connect the top and bottom main body sheet with 5brass straight pins(part 3) round head screws(part6).
step15 _meitu_17
Step 13
Fix the “leg” assembled in step 9 on the following place (showing with the red arrow) with a self-tapping screw (part 13).
step16 _meitu_18
step17 _meitu_19
step14
Fix the servo up with a sink head screw and a screw nut to ensure the stability of the servo. So far we have finished a “leg”; you can assemble the rest legs according to the above steps.
step18 _meitu_20
Assemble the followint legs in the same way,  and your Hexypider should look like this one.
10
Here you can get a set of the Hexipider.  Good luck!
Written By
More From Author
