DIY your own 3D Printer- part 2
 As last time ,we have finished  the Yaxis part,today we will go on with all machine part.
3 Assemble Y – Z axis
Required number
Required parts
1
X-Z frame
4
M3 x 20 screw
4
M3 nut
4 Mount the fan
Required number
Required parts
1
Fan
4
M3 x 30 screw
4
M3 locknut
5 Assemble the right and left side panel
Required number
Required parts
1
Acrylic left frame
1
Acrylic right frame
8
M3 x 16 screw
8
M3 square nut
Step1. Screw up the X-Z frame and the side panel then connect the rear part of the Y axis and the side panel together. You may need to adjust the distance of the X-Z frame to the rear plate.
All you need here is M3 x 16 screws and M3 square nuts.
6       Assemble the Z axis (the vertical axis)
6.1 Assemble the Z-axis bottom mount
Required number
Required parts
2
Z Motor fixed plate
4
Z Motor support plate
10
M3 x 16 screw
10
M3 square nut
6.2 Assemble the 2 Z motors
Required number
Required parts
2
Stepper Motor
8
M3 x 12screw
Step2. Screw up the motors with 4 M3 x 12 screws. Do the same with the other Z
motor.
7       Assemble the X axis (the horizontal axis)
7.1 Assemble the smooth rods.
Required number
Required parts
2
370mm smooth rod
2
LM8UU linear bearing
Slide the two bearings into the two rods respectively.
7.2 Assemble the X-Axis Idler
Required number
Required parts
2
624ZZ Ball bearing
1
Bearing holder
1
M3 X30 screw
1
M4 X25 screw
1
M4 locknut
Step1. Put the screw through the Y bearing holder.
7.3 Assemble the X-Axis end
Required number
Required parts
1
X-axis left end
1
X-axis right end
2
1
M3 wing nut
2
M3 x 16 screw
2
M3 nut
Step2. Lock it up tightly with a wing nut and insert a linear bearing into the slot. Pay attention to the direction of the idler. Please lock the M3X30 screw tightly in case any jam caused for the belt.
7.4 Assemble the X-axis rods and both ends
Required number
Required parts
2
Brass nut
8
M3 x 16 screw
1
M3 x50 screw
1
M3 nut
2
Screw locking ring
7.5 Mount the X-axis belt bracket on the smooth rods.
Required number
Required parts
1
print bracket
4
Zip tie
2
* the stretching-out part is towards the Left end of X axis.
7.6 Mount the extruder holder.
Required number
Required parts
1
Extruder bracket
2
M4 x 16screw
2
M4 nut
Step1. Put the 2 M4 nut into the hole, as shown in the picture.
7.7 Mount the extruder
Required number
Required parts
1
MK8 dual extruder
2
M4 x 12 screw
2
M4 nut
7.8 Mount the fan for extruder
Required number
Required parts
1
Fan
2
M3 x 30 screw
2
M3 washer
7.9 Mount the X-axis motor.
Required number
Required parts
1
Stepper motor
1
Pulley
3
M3 x 8 screw
Please pay attention to the mount direction of the pulley, which is opposite to that of the Y-axis.
7.10 Amount the X-axis belt.
Required number
Required parts
1
Timing Belt
2
Zip tie
*Pay attention to the tooth mesh of the belt and that on the bracket. Tie up both ends tightly. (This bracket may be a bit different from yours, but it doesn’t matter)
In this step, when attach the second side of the timing belt for the x-axis, h you may not estimate accurately the length of the whole belt until the z-axis stage has been mounted. So, please do not rush to cut the extra belt, you need to re-adjust it later after the z-axis has been mounted.
8 Assemble the X-Z axis.
Required number
Required parts
2
Couplings
2
L322 threaded rod
*Mind the opening of the couplings, the larger opening should be connected to the threaded rods.
(Please ignore the MK8 extruder in this picture, if you are moving to this step, please send me a right picture with dual extruder, thanks.)
Required number
Required parts
2
Z-axis top mount
4
M3 x 16 screw
4
M3 square nut
9 Attach he heated bed.
Required number
Required parts
1
MK2A Heat bed
1
Borosilicate glass
2
Heating wire
1
Thermistor
2
Thermometry wire
4
Wing nut
4
Spring
4
M3 x35 screw
4
clamp
Step5. Mount the heat bed on the platform with 4 M3 x35 screws and wing nuts with springs in between.  Clamp the heat bed and the glass sheet.
*the soldered side is better to be attached downwards.
10 Mount the end stops.
Step 1.End stop of X-axis
Required number
Required parts
1
End stop
2
M2.5 X 12 screw
Step2. End stop of Y-axis
Required number
Required parts
1
End stop
2
M2.5 X 16 screw
                2
M2.5 Hex nut
Step3. End stop of Z-axis
Required number
Required parts
1
End stop
2
M 3 X 16 screw
2
M 3 nut
Here, you may need to use a bit force to drill the screw into the endstop.
11    Mount the LCD panel frame.
Required number
Required parts
1
LCD 2004
1
LCD frame
2
LCD frame holder
4
Acrylic washer
6
M3 x 20 screw
4
M3 nut
12 Mount the PSU
Required number
Required parts
1
Power supply
3
M3 x 10 screw
2
M3 x 16 bolt
2
M3 nut
1
3D Power cable
1) Mind the color of the wires. The wrong connection of the wire will cause serious damage to the PSU and even to the control board of the printer.
2) Pay attention to the switch on the right side of the PSU, there are two options of voltage: 110 V and 220V, choose according the standard in your country. As shown in the following picture. You can use some hard sticks to reach the switch.
see the finished picture here.
So far, we have finished  all  machine part, that’s all for today, tomorrow, we will continue with the building electric of the Prusa i3. Stay tuned!
for more detailed introduction of Geeetech prusa I3, please refer to geeetech online store.
Written By
More From Author
