Build my own 3D printer? yes, i am going to share with you a step- by-step instruction on how to build your own 3d printer.
when it comes to DIY 3d printer, what comes into my mind is prusa I3 series or the delta rostock series, yes, these two types of 3d printer are the most famous and easy 3d printers for DIYers, especially starters in 3d printing. so today, we will take our prusa I3 pro B as an example.
of cause, you must have one 3d printer http://www.geeetech.com/acrylic-geeetech-i3-pro-b-3d-printer-kit-p-917.html
Preparation
8. Ask for help if you run into any problems – our contact details are on the website and we will always do our best to resolve any problems encountered.
1 Unfold the box and check the package
All the acrylic plate has been etched with part ID and the plate is covered with a sheet of kraft paper, you need to tear them off.
Tips:
2 Assemble Y axis
2.1 Assemble the rods of a Y axis
Required number |
Required parts |
2 |
M10 threaded rod |
2 |
Y plate connecting plate |
6 |
M8 spring washer |
8 |
M10 washer |
8 |
M10 nut |
Required number |
Required parts |
2 |
M8 smooth rod |
4 |
LM8UU Linear bearings |
1.2. Attach the front and rear Acrylic support plates of the rods.
Required number |
Required parts |
2 |
Acrylic plate( front) |
2 |
Acrylic plate( rear) |
4 |
M10 washer |
4 |
M10 nut |
* Tips:
2.2 Assemble the Y idler
Required number |
Required parts |
2 |
624ZZ Ball bearing |
1 |
bearing holder |
1 |
M3 x 20 screw |
1 |
M3 wing nut |
1 |
M4 x25 screw |
1 |
M4 lock nut |
Step1. Thread the M3 x 20 screw through the bearing holder.
2.3 Mount the Y motor
Required number |
Required parts |
1 |
Y motor fix plate |
1 |
Stepper motor |
1 |
pulley |
3 |
M3 x 12 screw |
2 |
M3 x 16 screw |
2 |
M3 square nut |
2.4 Build the printing platform
Required number |
Required parts |
1 |
Y platform support |
4 |
Y bearing block |
1 |
Y belt mount |
4 |
Zip tie |
2 |
M3 x 10 screw |
8 |
M3 x 20 screw |
8 |
M3 nut |
Step2. Mount the 4 bearing blocks on the platform with M3 x 20 screws on the same side with the belt-mount. Screw with M3 nuts.
2.5 Mount the Y –axis belt.
Required number |
Required parts |
1 |
Timing belt |
2 |
M3 x 10 screw |
2 |
M3 washer |
*Tips:
1. Before you drill your second hole, make sure to pull belt tightly to make sure to find proper placement of hole for a tight belt, if it is too loose, it will hinder the move of the print platform.
2. Loosen the Y idler wing nut when tightening belt onto the Y belt mount [No. 67] in order to make securing the belt to the block easier. Be sure to tighten wing nut fully once done.
So far, we have finished the Yaxis part, that’s all for today, tomorrow, we will continue with the building the X axis of the Prusa i3. Stay tuned!
for more detailed introduction of Geeetech prusa I3, please refer to geeetech online store.
