Geeetech Thunder 3D printer
Revision as of 08:18, 1 July 2023 by Admin (talk | contribs) (Firmware Upgrading)
Jump to: navigation, search
•Technology: FDM
•Dual Z-axis
•Break-resuming capability
Notice
Cura Configuration File
User Mode Introduction
Smatto Kits
•First Layer Mode
•Curve Mode
•Corner Line Threshold
•Max Junction
•X/Y Frequency
•Acceleration
•Jerk
•Extruder
General Page
Motor Page
PID Page
Custom Page
Firmware Upgrading
UI Upgrading
How to clean the hotend
How to replace a nozzle
2. Remove the heat block kit.
How to replace a hotend
1. Disassemble the hotend kit
2. Install the new hotend kit
How to use smarttokits
Smatto Kits
•First Layer Mode
•Curve Mode
•Max Junction
•X/Y Frequency
•Acceleration
•Jerk
•Extruder
General Page
Motor Page
PID Page
Custom Page
How to upgrade firmware
How to upgrade UI
How to print with cura
Nothing is printing
Mintemp error
Automatic leveling failed
(a)3D Touch is abnormal
(b)Homing failed
(c)The first layer is messy
Spring steel sheet problem
Filament sensor
Nozzle discharge abnormality
First layer abnormal
Layer shift
=='Filament'==
Part Cooling Fan:
M106 P0 S128 ; ON MainFan 50%
M106 P1 S128 ; ON Aux Fan 50%
M106 P1 S0 ; OFF Aux Fan
