Geeetech Thunder 3D printer
Jump to: navigation, search
•Technology: FDM
•Dual Z-axis
•Break-resuming capability
How to clean the hotend
How to replace the nozzle
How to replace the heat block kit
2. Remove the heat block kit.
How to replace the hotend
1. Disassemble the hotend kit
2. Install the new hotend kit
How to replace the power supply
How to auto leveling
How to manual leveling
How to upgarde UI
How to upgarde firmware
How to use Smarttokits
Smatto Kits
•First Layer Mode
•Curve Mode
•Corner Line Threshold
•Max Junction
•X/Y Frequency
•Acceleration
•Jerk
•Extruder
General Page
Motor Page
PID Page
Custom Page
How to print with Cura
Nothing is printing
Mintemp error
Automatic leveling failed
(a)3D Touch is abnormal
(b)Homing failed
(c)The first layer is messy
Spring steel sheet problem
Filament sensor
Nozzle discharge abnormality
First layer abnormal
Layer shift
=='Filament'==
Part Cooling Fan:
M106 P0 S128 ; ON MainFan 50%
M106 P1 S128 ; ON Aux Fan 50%
M106 P1 S0 ; OFF Aux Fan
