Geeetech Thunder 3D printer
Contents
[hide]- 1 Introduction
- 2 Product Features
- 3 Parameters
- 4 Notice
- 5 Cura Configuration File
- 6 User Mode Introduction
- 7 Firmware Upgrading
- 8 UI Upgrading
- 9 Settings of Nozzle with Different Diameter
- 10 HS-PLA Series Filament "Speed-Temperature" Parameter Settings for Reference
- 11 X/Y Axis Closed-loop Motor Calibration and Abnormality Elimination
- 12 Usage Suggestions
- 13 Printer Maintenance
- 13.1 How to clean the hotend
- 13.2 How to replace a nozzle
- 13.3 How to replace a heat block kit
- 13.4 How to replace a hotend
- 13.5 Turn the printer on but the screen is black
- 13.6 The extruder keeps making a click sound
- 13.7 Nothing is printing
- 13.8 Mintemp error
- 13.9 Automatic leveling failed
- 13.10 Spring steel sheet problem
- 13.11 Filament sensor
- 14 FAQ
- 15 How to Acquire Support
- 16 How to Buy
Product Features
•Technology: FDM
•Dual Z-axis
•Break-resuming capability
Parameters
Notice
•First Layer Mode
•Curve Mode
•Corner Line Threshold
•Max Junction
•X/Y Frequency
•Acceleration
•Jerk
•Extruder
General Page
Motor Page
PID Page
Custom Page
Firmware Upgrading
UI Upgrading
Usage Suggestions
2. Remove the heat block kit.
- d.Release the screw terminals for heater cartridge and remove the cables. Unplug the cables of hotend and the hotend fan.
- d.Place back all the pieces to reassemble the print head. Make sure the cables are fully inserted and tightened!
1. Disassemble the hotend kit
2. Install the new hotend kit
Nothing is printing
Mintemp error
(a)3D Touch is abnormal
(b)Homing failed
(c)The first layer is messy
Filament sensor
Nozzle discharge abnormality
First layer abnormal
Layer shift
Filament
Part Cooling Fan:
M106 P0 S128 ; ON MainFan 50%
M106 P1 S128 ; ON Aux Fan 50%
M106 P1 S0 ; OFF Aux Fan
Steps:
