Mizar M
Revision as of 09:10, 9 May 2023 by Admin (talk | contribs) (Printer maintenance)
Jump to: navigation, search
Unique Separated Color Module
Product details
Main specification
Technology: FDM
Printing Thickness: 0.1-0.2mm
Nozzle Diameter: 0.4mm
Printing Accuracy: ±0.1mm
Printing Speed: 20~150mm/S
Hotbed Max Temperature: 110℃
Nozzle Max Temperature: 250℃
Working temperature: 10-40℃
Electric Parameter
Hotbed Size: 260*260mm
Net Weight: 10.2kg
Gross Weight: 13kg
Unpacking and proper handling
Slicing
Cura
Mizar M Cura Configuration
Mizar M Configuration
File Path
Cura 5.X
Cura 4.X
Cura Profile
Separate Color Printing
Gradient Color printing
  • G-code Instructions
M163 Set a mix factor
M164 Save mix factor
M166 Gradient for Marlin 2.0
A= Start z height
Z= End z height
I= Start Virtual Tool
J= End Virtual Tool
M163  ;Set a mix factor M164  ;Save mix factor
M163 S0 P1
M163 S1 P0
M164 S0 ;T0=100/0
M163 S0 P1; 100% Red
M163 S1 P0; 0% Green
M163 S0 P0; 0% Red
M163 S1 P1; 100% Green
M166 A0 Z250 I0 J1 S1
mix.
M166 A0 Z250 I0 J1 T3
T3
M166 T
T0
M163 S0 P1
M163 S1 P0
M164 S0  ;T0=100/0
M163 S0 P0
M163 S1 P1
M164 S1  ;T1=0/100
M163 S0 P0.5
M163 S1 P0.5
M164 S2  ;T2=50/50
M166 A0 Z100 I0 J1 S1  ;Gradient Usage Instructions 1
M163 S0 P1
M163 S1 P0
M164 S0  ;T0=100/0
M163 S0 P0
M163 S1 P1
M164 S1  ;T1=0/100
M163 S0 P0.5
M163 S1 P0.5
M164 S2  ;T2=50/50
M166 A0 Z100 I0 J2 T3  ;Gradient Usage Instructions 2
Easy Print
Easy Print Slicer
Gradient Color Printing
Prusa Slicer
Mizar M Prusa Configuration
Separate Color Module
Simplify 3D
Printer maintenance
Hotend clogging
Mintemp error
Nothing is printing
Automatic leveling failed
Spring steel sheet problem
Filament sensor
