Geeetech Thunder 3D printer
Contents
[hide]- 1 Introduction
- 2 Product Features
- 3 Parameters
- 4 Notice
- 5 Cura Configuration File
- 6 User Mode Introduction
- 7 Firmware Upgrading
- 8 UI Upgrading
- 9 Settings of Nozzle with Different Diameter
- 10 HS-PLA Series Filament "Speed-Temperature" Parameter Settings for Reference
- 11 X/Y Axis Closed-loop Motor Calibration and Abnormality Elimination
- 12 Usage Suggestions
- 13 Printer Maintenance
- 14 FAQ
- 15 How to Acquire Support
- 16 How to Buy
Product Features
•Technology: FDM
•Dual Z-axis
•Break-resuming capability
Parameters
Notice
•First Layer Mode
•Curve Mode
•Corner Line Threshold
•Max Junction
•X/Y Frequency
•Acceleration
•Jerk
•Extruder
General Page
Motor Page
PID Page
Custom Page
Firmware Upgrading
UI Upgrading
Usage Suggestions
How to clean the hotend
How to replace a nozzle
2. Remove the heat block kit.
- d.Release the screw terminals for heater cartridge and remove the cables. Unplug the cables of hotend and the hotend fan.
- d.Place back all the pieces to reassemble the print head. Make sure the cables are fully inserted and tightened!
How to replace a hotend
1. Disassemble the hotend kit
2. Install the new hotend kit
Nozzle discharge abnormality
First layer abnormal
Layer shift
Filament
Part Cooling Fan:
M106 P0 S128 ; ON MainFan 50%
M106 P1 S128 ; ON Aux Fan 50%
M106 P1 S0 ; OFF Aux Fan
Steps:
