Geeetech Thunder 3D printer
Contents
- 1 Introduction
- 2 Product Features
- 3 Parameters
- 4 Notice
- 5 Cura Configuration File
- 6 User Mode Introduction
- 7 Firmware Upgrading
- 8 UI Upgrading
- 9 Settings of Nozzle with Different Diameter
- 10 HS-PLA Series Filament "Speed-Temperature" Parameter Settings for Reference
- 11 X/Y Axis Closed-loop Motor Calibration and Abnormality Elimination
- 12 Daily Maintenance and Usage Suggestions
- 13 FAQ
- 14 How to Acquire Support
- 15 How to Buy
Product Features
•Technology: FDM
•Dual Z-axis
•Break-resuming capability
Parameters
Notice
•First Layer Mode
•Curve Mode
•Corner Line Threshold
•Max Junction
•X/Y Frequency
•Acceleration
•Jerk
•Extruder
General Page
Motor Page
PID Page
Custom Page
Firmware Upgrading
UI Upgrading
Nozzle discharge abnormality
First layer abnormal
Layer shift
Filament
G-code for main fan and auxiliary fan
Main Fan:
M106 P0 S128 ; ON MainFan 50%
Auxiliary Fan:
M106 P1 S128 ; ON Aux Fan 50%
M106 P1 S0 ; OFF Aux Fan
Steps:
