Geeetech Thunder 3D printer
Revision as of 07:41, 13 September 2022 by Admin (talk | contribs) (HS-PLA Series Filament "Speed-Temperature" Parameter Settings for Reference)
Jump to: navigation, search
Product Features
•Technology: FDM
•Dual Z-axis
•Break-resuming capability
Parameters
Notice
Cura Configuration File
Thunder Cura 4.13 Configuration
User Mode Introduction
Smatto Kits
•First Layer Mode
•Curve Mode
•Corner Line Threshold
•Max Junction
•X/Y Frequency
•Acceleration
•Jerk
•Extruder
General Page
Motor Page
PID Page
Custom Page
Firmware Upgrading
UI Upgrading
HS-PLA Filament "Speed-Temperature" Comparison Table for Thunder
Nozzle discharge abnormality
First layer abnormal
Layer shift
Filament
How to Acquire Support
Steps:
How to Buy
Click to Purchase
