Geeetech Thunder 3D printer
Revision as of 04:02, 16 August 2022 by Admin (talk | contribs) (Product Features)
Jump to: navigation, search
Product Features
•Technology: FDM
•Dual Z-axis
•Break-resuming capability
Product Specifications
•CPU: ARM Cortex-M4 Core, 168MHz
•Printing Speed: ≤300mm/s
•Maximum Acceleration: x=5000mm/s², y=4000mm/s²
•Motion Controller CPU: ARM Cortex-M3 Core, 72MHz
•Nozzle Max Temperature: 250℃
•Hotbed Max Temperature: 110℃
•Nozzle Diameter(Optional): 0.2mm, 0.6mm, 0.8mm
•Filament Diameter: 1.75mm
•Power Input: AC 115/230V, 50/60Hz
•Power Supply: 350W
•Net Weight: 10.7kg
•Packing Weight: 13.4kg
Notice
Cura Configuration File
User Mode Introduction
•First Layer Mode
•Curve Mode
•Corner Line Threshold
•Max Junction
•X/Y Frequency
•Acceleration
•Jerk
•Extruder
General Page
Motor Page
PID Page
Custom Page
Firmware Upgrading
THUNDER does not support TF card upgrading firmware directly. You need to use Smartto Kits to upgrade the firmware through the USB cable. The steps are as follows:
4.Click the "Disconnected" button in the upper right corner. The Setting sidebar is displayed in left side. Select the serial port for THUNDER, set the serial port baud rate to 115200, and click "Connect" to Connect THUNDER.
UI Upgrading
A TF card or USB flash drive is required to upgrade the UI of THUNDER. See following steps:
Step 2: Insert the TF card or USB drive into THUNDER, and then power on THUNDER. At this time, you will see that the display screen is updating the UI. This process takes a long time, please wait patiently.
In addition to the 0.4mm diameter, THUNDER also supports 0.2mm, 0.6mm and 0.8mm diameter nozzles. For these diameter nozzles that is not commonly used, there are some parameters that need to be set and adjusted when using the slicing software. Based on experience and validation, we offer 0.2mm, 0.6mm, 0.8mm diameter nozzle slice parameters for THUNDER for user reference, see the table below (or download the Excel table).
THUNDER's X/Y axis motors are all closed-loop controlled, and the closed-loop control sensors on the motors have been calibrated before delivery. Do not remove the closed-loop control sensor if the X-axis and Y-axis are not abnormal. Otherwise it will cause the calibration parameters of the closed-loop control sensor on the X-axis and Y-axis to be offset, resulting in the X-axis or Y-axis stuttering or abnormal jitter during the THUNDER printing process.
On the screen menu of THUNDER, we provide the X-axis and Y-axis closed-loop control sensor calibration function. The specific path is "Operate" → "Motion". In the "Motion" menu, you can see two buttons "X Encoder Cal" and "Y Encoder Cal". They are X-axis and Y-axis closed-loop control sensor calibration buttons respectively. The specific calibration methods are as follows:
Nozzle discharge abnormality
First layer abnormal
Layer shift
