I have read in other threads that there are no .stl files available for the I3 X because the frame is laser cut acrylic. I understand why the files don't exist, but I am in need of several replacement parts.
I have broken a few pieces of my printer (mostly where the square nuts pull two pieces together) and would like to replace the with something stronger, like aluminum or stainless steel. Eventually I think that it would look awesome and be great to replace the entire frame. I have access to a variety of machines that could cut a part to replace my broken piece. I am familiar with several professional CAD programs and file types, and I'm very capable of just doing a CAD model of the parts I need if the files aren't available.
Are there any 2D or 3D .dxf, .dwg, .stp, or other files that I could use to cut replacement pieces for my I3 X?
CAD files for I3 X acrylic parts
Re: CAD files for I3 X acrylic parts
nope, no such files,...
Thank you for your response. Since there are no replacement parts available to purchase, I will post in the forum any CAD files that I create.
I have a few....won't let me upload here...let me know where to send them....
Subscribing to this thread. I would love to have a copy of those files to print backups for the printer. Thanks!
So I've been busy printing parts for a larger CNC router/mill as well as designing some other unrelated things.
This weekend I plan on finishing a model of the piece at the top of the Z-axis and making a second variation of that same piece with a slot for a 608 bearing (I picked that size because I happen to have quite a few of them laying around).
As a whole, I'm limiting my efforts to parts that can be printed on the provided bed and will possibly combine assemblies such as the X carriage pieces and the Z-axis motor mounts. Sorry for the delay, I hope anybody that has been waiting can forgive me.
It just always seemed odd that the laser cutter that made the originals would use CAD files but they aren't accessible to us. So I'm going to try my best.
I finished the model for part number i3B1-08. It is the top piece to the Z-axis on both sides and should be interchangeable. A few external dimensions are different, but they won't affect functionality other than improving strength.
An interesting thing to note is that the frame is mostly measured out to standard measurements. I found that most of the measurements I was making ended up being common measurements. One thing to note would be that the frame thickness is actually less than 8mm. It's a very standard 5/16 inch thick (~7.66mm).
Print with PLA for accuracy, and at least 60% infill for strength. No raft.
Here is the link to a hosted file if the attachment does not work. http://www.thingiverse.com/thing:1307163
- v0i3B1-08.zip
- (18.23 KiB) Downloaded 1633 times
Does somebody has a Y-motor holder STL or a CAD file? Would zou send it to me? Thanks in advance.
I will work on it tonight and post it here.
I also realized that I never actually posted the .dxf file for the other one, so I guess I'll do that now.
- i3B1-08.zip
- (63.69 KiB) Downloaded 1684 times
[attachment=0]y_-_axis_idler.7z A few STL files I have for the pro x
- y_-_axis_idler.7z
- Put over the bearing open with winzip
- (10.52 KiB) Downloaded 1387 times
