Hi everybody,
I made the lastest Marlin for ours I3 Pro B, it´s with T8x2 rod, S Curve Acceleration activated and leveling mesh 4x4 points.
The repository it´s located at https://github.com/lachusmadeti
Any suggestion or problem don´t hesitate to say me for correct it.
Best regards.
Marlin 2.0.6
Marlin 2.0.6
Please, support my collaboration, buy me a Kofi https://ko-fi.com/lachusmadeti THANKS!!
Re: Marlin 2.0.6
Thank you for sharing! Excellent!:D
![Smile :)](./images/smilies/icon_e_smile.gif)
Re: Marlin 2.0.6
Hi! Thanks for sharing!
How to modify it for normal z axis rods?
Have a nice day!
Have a nice day!
Re: Marlin 2.0.6
If you have the normal M8 rods are 2500 microsteps, for Tr8x8 are 400 microsteps.
Best regards
Re: Marlin 2.0.6
First of all, thank you so much for the firmware!! Great stuff ![Smile :)](./images/smilies/icon_e_smile.gif)
Just a quick question: I've uploaded the firmware by disabling the leveling (I don't have it yet), but homing always give -12 on X axis (Y and Z behave normally). X-stopper works perfectly, the printer detects it, but the coordinate is always -12 there. Not a big deal I guess, but seems a bit odd
Do you by any chance know what can be causing this? Anyone observed the same?
Re: Marlin 2.0.6
Your article content is being very much interested, I am very impressed with your post. I hope to receive more great posts.
walgreenslistens
walgreenslistens
Re: Marlin 2.0.6
I think you were directly about overflowing material. With brushing off ,1.5mm withdrawal and 0.6mm Z-jump primer tests hope to have tackled this issue, anyway it did noticabley lower surface quality which is additionally not ideal. Im going to try different things with longer than 2mm withdrawal lengths despite the fact that it is normally exhorted against for direct drive arrangements. Im speculating the withdrawal just isnt long enough for this Volcano/Titan clone.
GarageBand
GarageBand
Re: Marlin 2.0.6
Buena! Me llamo Juan y hace poco me compre una impresora i3 pro b. Viene completamente en blanco y he intentado instalarle marlin siguiendo tutotiales que he encontrado por internet y nada de nada. La pantalla sigue sin salir nada. Podria ayudarme un poco? Gracias de antemano
Re: Marlin 2.0.6
It's normal, I defined at the firmware the offset of the X axis, if you meassure when home the printer the distance from the nozzle to the white line of starting print area it's 12mm.Darkmind wrote: ↑Wed Jan 20, 2021 10:40 amFirst of all, thank you so much for the firmware!! Great stuff
With this when you mark to print at the center of the bed really print at center.
The levelling I defined it's manual leveling, the firmware isn't for the BL Touch/3DTouch.
Best regards.
Re: Marlin 2.0.6
Buenas Juan,JuAnGrAxXx wrote: ↑Tue Feb 02, 2021 2:30 amBuena! Me llamo Juan y hace poco me compre una impresora i3 pro b. Viene completamente en blanco y he intentado instalarle marlin siguiendo tutotiales que he encontrado por internet y nada de nada. La pantalla sigue sin salir nada. Podria ayudarme un poco? Gracias de antemano
la placa se enciende? puedes conectar con ella mediante Arduino IDE o pronterface? Revisa las conexiones de la placa a la pantalla, a ver si estuviesen cambiadas las del LCD por el lector de SD.
Un saludo
