Geeetech Mizar M 3D printer
Revision as of 01:57, 1 July 2023 by Admin (talk | contribs) (Unpacking and proper handling)
Jump to: navigation, search
Unique Separated Color Module
Main specification
Technology: FDM
Printing Thickness: 0.1-0.2mm
Nozzle Diameter: 0.4mm
Printing Accuracy: ±0.1mm
Printing Speed: 20~150mm/S
Hotbed Max Temperature: 110℃
Nozzle Max Temperature: 250℃
Working temperature: 10-40℃
Electric Parameter
Hotbed Size: 260*260mm
Net Weight: 10.2kg
Gross Weight: 13kg
Slicing
Cura
Mizar M Cura Configuration
Mizar M Configuration
File Path
Cura 5.X
Cura 4.X
Cura Profile
Separate Color Printing
Gradient Color printing
  • G-code Instructions
M163 Set a mix factor
M164 Save mix factor
M166 Gradient for Marlin 2.0
A= Start z height
Z= End z height
I= Start Virtual Tool
J= End Virtual Tool
M163  ;Set a mix factor M164  ;Save mix factor
M163 S0 P1
M163 S1 P0
M164 S0 ;T0=100/0
M163 S0 P1; 100% Red
M163 S1 P0; 0% Green
M163 S0 P0; 0% Red
M163 S1 P1; 100% Green
M166 A0 Z250 I0 J1 S1
mix.
M166 A0 Z250 I0 J1 T3
T3
M166 T
T0
M163 S0 P1
M163 S1 P0
M164 S0  ;T0=100/0
M163 S0 P0
M163 S1 P1
M164 S1  ;T1=0/100
M163 S0 P0.5
M163 S1 P0.5
M164 S2  ;T2=50/50
M166 A0 Z100 I0 J1 S1  ;Gradient Usage Instructions 1
M163 S0 P1
M163 S1 P0
M164 S0  ;T0=100/0
M163 S0 P0
M163 S1 P1
M164 S1  ;T1=0/100
M163 S0 P0.5
M163 S1 P0.5
M164 S2  ;T2=50/50
M166 A0 Z100 I0 J2 T3  ;Gradient Usage Instructions 2
Easy Print
Easy Print Slicer
Gradient Color Printing
Prusa Slicer
Mizar M Prusa Configuration
Separate Color Module
Simplify 3D
Printer maintenance
Hotend clogging
Mintemp error
Nothing is printing
Automatic leveling failed
(a)3D Touch is abnormal
(b)Homing failed
(c)The first layer is messy
Spring steel sheet problem
Filament sensor
How to update:
4.Update is complete.
Notice:
