Metal J-head long-distance
Jump to: navigation, search
The Bowden cable lets you reduce the moving mass of the extruder and thus allowing faster controlled motion, less shaking of your machine, less energy use and importantly: faster printing! Normally the mechanism that drives the filament into the hot end (where it melts) is directly on top of the extruder. This creates problems of balance and oscillations with faster motion which you can see in your printing results and hear and feel when your machine is shaking.
If the filament drive mechanism is placed on a non-moving part of the 3D printer, it can be pushed into a tube. PTFE (Teflon) is useful because it is slippery: it has little friction with the plastic.This limits wear and loss of energy. The tube's other end is connected to the extruder's hot-end.
The concept of using a Bowden cable as guide was suggested and pioneered by Ed Sells.
The main advantages
Configurable cooling fan, cooling effect Metal J-head long-distance
Product Introduction
Printing resolution 0.1mm
Molding form FDM
Material Metal
Nozzle temperature 180℃-240℃
Outline dimensions 85*25*25mm L/H/W
Weight 75g
Input voltage default to 12V
Cartridge heater 12V 30W
Click here to buy Metal J-head long-distance
http://www.geeetech.com/all-metal-longdistance-jhead-for-bowden-extruder-p-784.html
