Geeetech M1 3D printer
Contents
- 1 Printer Introduction
- 2 Printer Maintenance
- 3 Trouble Shooting
- 3.1 Black Screen
- 3.2 Update Firmware
- 3.3 Minimum Temperature Error
- 3.4 Filament cannot be extruded
- 3.5 Print file is not displayed
- 3.6 How to Import Profiles into Cura
- 3.7 How to import configuration files into Orcaslicer
- 3.8 The consumables don't stick to the hot bed
- 3.9 The print is brushed or leaked
- 3.10 Underextrusion and overextrusion
- 3.11 The top-level seal is insufficient
- 3.12 Print offset
- 3.13 Surface spots and stripes problems
- 3.14 There are gaps between the edge and the filling
- 3.15 Rough edges and corners
- 3.16 Top layer surface scratch problem
- 3.17 Holare holes in the bottom of the corner linet
- 3.18 The side edges are uneven
- 3.19 How to print PLA
- 3.20 How to print TPU
- 3.21 How to print ABS
- 3.22 How to print PETG
Main specifications
Printer type: FDM
Layer thickness: 0.1-0.2 mm
Automatic leveling: Yes
Breakpoint resume: Yes
Nozzle diameter: 0.4 mm
Printing accuracy: ±0.1 mm
Ambient temperature: 10-40 ℃
Power Input:
Net Weight(kg): 3 kg
Gross Weight(kg): 4 kg
How to Clean the Nozzle
How to Replace the Hot End
How to Replace the Screen
How to Automatically Level
How to Manually Level
Black Screen
1、 Before printing, the filament is not loaded in place Solution: Stop printing first, and heat the nozzle temperature to the appropriate temperature. Set the PLA material to 200 degrees, the PETG material to 230 degrees, and the ABS material to 240 degrees, and then feed manually
2、 The nozzle is too close to the platform Solution: Perform manual leveling or automatic leveling, and readjust the printer platform. It is recommended that the distance between the nozzle and the platform is 0.3mm, which is the thickness of an A4 sheet
3、 The printer is blocked Solution: Use a needle to clean the nozzle deeply. First, heat the nozzle temperature to between 230 and 250, and pull out the filament when the temperature reaches the set value, and then use our matching needle to insert the small hole of the nozzle from bottom to top to repeatedly dredge it. After cleaning, manually insert the filament until the nozzle flows out of the filament normally.
First of all, it is stated that the slice file must be in .gcode format. The printer cannot recognize other formats
(2) Click Import
(3) Click Import Configs...
3.The extruder is not working
How to print PLA
Nozzle temperature: 190-210℃
Bed temperature: 30-60℃
Fan Cooling: 100%
Nozzle temperature: 220-230℃
Fan Cooling: 100%
How to print ABS
Nozzle temperature: 230-250℃
Bed temperature: 90-110℃
Fan Cooling: 0%
How to print PETG
Nozzle temperature: 220-250℃
Bed temperature: 70-80℃
Fan Cooling: 30%
