Geeetech M1 3D printer
Contents
- 1 Printer Introduction
- 2 Printer Maintenance
- 3 Trouble Shooting
- 3.1 Black Screen
- 3.2 Update Firmware
- 3.3 Minimum Temperature Error
- 3.4 How to Import Profiles into Cura
- 3.5 How to import configuration files into Orcaslicer
- 3.6 The consumables don't stick to the hot bed
- 3.7 The print is brushed or leaked
- 3.8 Underextrusion and overextrusion
- 3.9 The top-level seal is insufficient
- 3.10 Print offset
- 3.11 Surface spots and stripes problems
- 3.12 There are gaps between the edge and the filling
- 3.13 Rough edges and corners
- 3.14 Top layer surface scratch problem
- 3.15 Holare holes in the bottom of the corner linet
- 3.16 The side edges are uneven
- 3.17 How to print PLA
- 3.18 How to print TPU
- 3.19 How to print ABS
- 3.20 How to print PETG
Main specifications
Printer type: FDM
Layer thickness: 0.1-0.2 mm
Automatic leveling: Yes
Breakpoint resume: Yes
Nozzle diameter: 0.4 mm
Printing accuracy: ±0.1 mm
Ambient temperature: 10-40 ℃
Power Input:
Net Weight(kg): 3 kg
Gross Weight(kg): 4 kg
How to Clean the Nozzle
How to Replace the Hot End
How to Replace the Screen
How to Automatically Level
How to Manually Level
Black Screen
4、 Copy all geeetech_M1.inst.cfg files to this path: \UltiMaker Cura 5.x.x\share\cura\resources\variants\geeetech_variants
(2) Click Import
(3) Click Import Configs...
3.The extruder is not working
How to print PLA
Nozzle temperature: 190-210℃
Bed temperature: 30-60℃
Fan Cooling: 100%
Nozzle temperature: 220-230℃
Fan Cooling: 100%
How to print ABS
Nozzle temperature: 230-250℃
Bed temperature: 90-110℃
Fan Cooling: 0%
How to print PETG
Nozzle temperature: 220-250℃
Bed temperature: 70-80℃
Fan Cooling: 100%
