Geeetech M1 3D printer
Contents
- 1 Printer Introduction
- 2 Printer Maintenance
- 3 Trouble Shooting
- 3.1 Black Screen
- 3.2 Update Firmware
- 3.3 Minimum Temperature Error
- 3.4 How to Import Profiles into Cura
- 3.5 How to import configuration files into Orcaslicer
- 3.6 The consumables don't stick to the hot bed
- 3.7 The print is brushed or leaked
- 3.8 Underextrusion and overextrusion
- 3.9 The top-level seal is insufficient
- 3.10 Print offset
- 3.11 Surface spots and stripes problems
- 3.12 There are gaps between the edge and the filling
- 3.13 Rough edges and corners
- 3.14 Top layer surface scratch problem
- 3.15 Holare holes in the bottom of the corner linet
- 3.16 The side edges are uneven
- 3.17 How to print PLA
- 3.18 How to print TPU
- 3.19 How to print ABS
- 3.20 How to print PETG
Main specifications
Printer type: FDM
Layer thickness: 0.1-0.2 mm
Automatic leveling: Yes
Breakpoint resume: Yes
Nozzle diameter: 0.4 mm
Printing accuracy: ±0.1 mm
Ambient temperature: 10-40 ℃
Power Input:
Net Weight(kg): 3 kg
Gross Weight(kg): 4 kg
How to Clean the Nozzle
How to Replace the Hot End
How to Replace the Screen
How to Automatically Level
How to Manually Level
Black Screen
1、 Copy the file geeetech M1.def, be careful to copy the .Json file and do not copy the wrong one
2、Open the location of the Cura file and copy the geeetech_M1.def.json file to this path:
\UltiMaker Cura 5.8.1\share\cura\resources\definitions
3、Copy the configuration file in the picture
4、Copy all geeetech_M1.inst.cfg files to this path: \UltiMaker Cura 5.x.x\share\cura\resources\variants\geeetech_variants
(2) Click Import
(3) Click Import Configs...
3.The extruder is not working
How to print PLA
Nozzle temperature: 190-210℃
Bed temperature: 30-60℃
Fan Cooling: 100%
Nozzle temperature: 220-230℃
Fan Cooling: 100%
How to print ABS
Nozzle temperature: 230-250℃
Bed temperature: 90-110℃
Fan Cooling: 0%
How to print PETG
Nozzle temperature: 220-250℃
Bed temperature: 70-80℃
Fan Cooling: 100%
