GLA10
Revision as of 07:25, 5 February 2024 by Admin (talk | contribs) (GLA10 Leveling Files Download Link)
Jump to: navigation, search
GEEETECH GLA10 3D Printer Leveling Auxiliary Tool(https://www.youtube.com/watch?v=Xxm0mE1Qrgs) GLA10 Leveling Files
Tips
① Please read this manual carefully for using GLA10 correctly.
②Please scan the QR code or log in to our website to get the G-code file that GLA10 needs.
③ Please pay attention to safety when leveling the GLA10 hot bed, so as not to hurt your fingers by the moving hot end.
Leveling Preparation
2. GCode generator for GLA10
We provide the corresponding G-codes for different hotbed sizes.Please edit the relevant information in the leveling Gcode generator.
Start Leveling
install Cura
Leveling test G-code
install Cura
install plug-in
3.Please find the submenu "Auto Towers" in the Cura main menu "Extensions" ,then click "Custom Bed Level Pattern" and select "Bed Level Pattern Type"according to your preference.
slice
Product Parameters
Battery parameter:CR2032,3V
Product weight:14.5g
Packing weight:52g
