GLA10
Revision as of 06:53, 5 February 2024 by Admin (talk | contribs) (Leveling Preparation)
Jump to: navigation, search
Tips
① Please read this manual carefully for using GLA10 correctly.
②Please scan the QR code or log in to our website to get the G-code file that GLA10 needs.
③ Please pay attention to safety when leveling the GLA10 hot bed, so as not to hurt your fingers by the moving hot end.
2. GCode generator for GLA10
We provide the corresponding G-codes for different hotbed sizes.Please edit the relevant information in the leveling Gcode generator.
Start Leveling
install Cura
Leveling test G-code
3.Please find the submenu "Auto Towers" in the Cura main menu "Extensions" and select "Custom Bed Level Pattern".
Product Parameters
Battery parameter:CR2032,3V
Product weight:14.5g
Packing weight:52g
