Filament
Revision as of 07:24, 20 July 2023 by Admin (talk | contribs)
Jump to: navigation, search
PLA
Bed temperature: 60-70 °C
Print speed: 60-100 mm/s
Initial layer height: 0.3 mm
Initial layer print speed: 20 mm/s
Travel Speed: At least 120 mm/s
Retraction distance: 6 mm for Bowden setups, 2-3 mm for direct drive setups
Retraction speed: 45 mm/s
Cooling fan speed:100%
(1) Level the hotbed
(2) Change the Z-offset
(3) Clean the hotbed
Silk PLA keeps clogging
Wood PLA keeps clogging
High Speed PLA
PETG
Bed temperature: 70-80 °C
Print speed: 40-50 mm/s
Retraction speed: 25 mm/s
Cooling fan speed: 30-40%
Build plate adhesion: Brim
ABS
Bed temperature: 80-100 °C
Cooling fan speed: 0%
TPU
Nozzle temperature: 200-210°C
Bed temperature: 60 °C
Print speed: 30-40 mm/s
