Geeetech Mizar S 3D Printer
Revision as of 06:25, 4 January 2023 by Admin (talk | contribs) (How to replace a hotend)
Jump to: navigation, search
Product details
Unpacking and proper handling
Slicing
Printer maintenance
Wrench size 10 mm
Allen keys – 1.5/2/2.5/3 mm
Diagonal pliers
Electrical tape
Zip ties
Craft knife or equivalent
Step 1 Preparing
Mizars002.png Preheat the nozzle to 220 Celsius from the LCD menu.
Mizars008.png Remove the hotend housing.
Disconnect the hotend thermistor.
Mizars009.png Release and remove the two screws that secure the hotend.
Remove the cables on the extension board.
Mizars011.png Remove the extension board and the part cooling fan.
Mizars012.png Remove the strain gauge.
Mizars013.png Remove the bottom cover and disconnect the cooling fan.
Mizars014.png Disconnect the heater cartridge.
Mizars016.png Cut off the heat-shrink tubing from the connection wire. Avoid cutting the cable.
Mizars018.png Remove the old heater cartridge.
Tweezers for nozzle
Wrench size 6/10/20 mm
Needle for nozzle
Allen key - 2 mm
Allen keys – 2.5/3 mm
How to replace PSU
Allen keys - 2.5/3 mm
How to replace a hotbed
Allen keys – 3 mm
Diagonal pilers
Zip ties
How to replace a screen
