Tiny6410
Revision as of 03:14, 13 December 2011 by Admin (talk | contribs)
Jump to: navigation, search
Tiny6410 | S3C6410 ARM11 Stamp Module
FriendlyARM Tiny 6410 Stamp Module with 533 MHz Samsung S3C6410 ARM11 processor.
Tiny6410 Schematics
Specification: Stamp Module
  • Dimension: 64 x 50 mm
  • CPU: 533 MHz Samsung S3C6410A ARM1176JZF-S with VFP-Unit and Jazelle (max freq. 667 MHz)
  • RAM: 128 MB / 256 MB DDR RAM, 32 bit Bus
  • Flash: 256 MB / 1GB NAND Flash
  • Serial, SPI, USB, LCD, CMOS Camera *Analog Input and Output
  • User Outputs: 4x LEDs
  • Expansion headers (2.0 mm)
  • Debug: 10 pin JTAG (2.0 mm)
  • OS Support
    • Windows CE 6
    • Linux 2.6
    • Android
    • Ubuntu
Specification: SDK-Board
  • Dimension: 180 x 130 mm
  • EEPROM: 1024 Byte (I2C)
  • Ext. Memory: SD-Card socket
  • Serial Ports: 4x DB9 (RS232)
  • IR: Infrared Receiver
  • USB: 1x USB-A Host 1.1, 1x miniUSB Slave 2.0
  • Audio Output: 3.5 mm stereo jack
  • Audio Input: 3.5mm jack
  • Ethernet: RJ-45 10/100M (DM9000)
  • RTC: Real Time Clock with battery
  • Beeper: PWM buzzer
  • TV Output: CVBS
  • LCD: 40 pin (2.0 mm) and 41 pin connector for FriendlyARM Displays and VGA Board
  • Touch Panel: 4 pin (resistive)
  • User Inputs: 8x buttons and 1x A/D pot
  • Power: regulated 5V (DC-Plug: 1.35mm inner x 3.5mm outer diameter)
Stamp Module
DK-Board + Stamp Module
Click here:http://www.geeetech.com/armavr-series-arm11-c-9_52.html
