Iduino Yun Cloud
Revision as of 08:55, 25 August 2016 by Admin (talk | contribs) (interface explanation)
Jump to: navigation, search
OverView
Interface explanation
  • Built-in web server
AVR Arduino microcontroller
  • Microcontroller ATmega32U4
  • Operating Voltage 5V
  • Input Voltage 5
  • Digital I/O Pins 20
  • PWM Channels 7
  • Analog Input Pins 12
  • SRAM 2.5 KB
  • EEPROM 1 KB
  • Clock Speed 16 MHz
Linux Microprocessor
  • Processor Atheros AR9331
  • Architecture MIPS @400MHz
  • Operating Voltage 3.3V
  • WiFi IEEE 802.11b/g/n
  • USB Type-A 2.0 Host
  • Card Reader Micro-SD only
  • RAM 64 MB DDR2
  • Flash Memory 16 MB
WiFi Specification
  • Connector: I-PEX connector.
USB Ports
The Iduino Yun Cloud has two USB connectors for different purpose:
Buttons:
  • WLAN_RESET: Reset Linux part.see here
  • 32u4_RSET: Reboot Atmega32u4
  • YUN_RST: Reboot Linux part
Quick Start of Iduino Yun
Connect to Iduino Yun
Choose Yun profile
Upload Bridge example
upload sketch to Yun
Test the sketch
User Manual
Getting IP address
Factory IP of Wifi port
FallBack IP
If the user’s laptop IP is
Detect IP from Arduino IDE
Access Method
Webpage access
webpage access
SSH Access
SSH access
SSH Access:
Port: 22
User Name: root
Password: iduino (default)
Webpage Setting
General setting
Upgrade
upgrade
upgrade
1 How to set up /www/sd and mnt/sd?
2 What if Arduino IDE doesn’t detect Iduino Yun Shield?
3 Where can you find the source code of the Iduino Yun?
4 How to upload, download or edit the files in Iduino Yun?
User name: root
Protocol: SCP
5 How to reset Iduino Yun?
6 How to recover the Iduino Yun in case firmware crash?
1.Turn of Windows firewall
5.Set TPFP service:
(2)Host: 192.168.255.2
Port:6666
Module IP: 192.168.255.1
Port: 6666
Local Port: 6666
Click "Listen":
13.Change "Local File"
14.Choose root-squashfs file
reset<CR>
Relevant file:
Reference
