Lora Shield
Revision as of 06:53, 31 May 2016 by Admin (talk | contribs)
Jump to: navigation, search
Hardware version info
Lora Shield v1.0: The first hardware release for the Lora Shield. Lora Shield v1.2: Connect the DIOs to Arduino IO. Change i-pex connector to SMA connector. Lora Shield v1.3: Remove 5v to 3.3v LDO, use 3.3 directly from Arduino +3.3v pin.
Wireless Specifications of RFM95W
168 dB maximum link budget. +20 dBm - 100 mW constant RF output vs. +14 dBm high efficiency PA. Programmable bit rate up to 300 kbps. High sensitivity: down to -148 dBm. Bullet-proof front end: IIP3 = -12.5 dBm. Excellent blocking immunity. Low RX current of 10.3 mA, 200 nA register retention. Fully integrated synthesizer with a resolution of 61 Hz. FSK, GFSK, MSK, GMSK, LoRaTM and OOK modulation. Built-in bit synchronizer for clock recovery. Preamble detection. 127 dB Dynamic Range RSSI. Automatic RF Sense and CAD with ultra-fast AFC. Packet engine up to 256 bytes with CRC. Built-in temperature sensor and low battery indicator.
Compatible with 3.3v or 5v I/O Arduino Board. Frequency Band: 868 MHZ/433 MHZ (Pre-configure in factory) Low power consumption Compatible with Arduino Leonardo, Uno, Mega, DUE External Antenna via I-Pex connector
Example1 -- Use with LMIC library for LoraWAN compatible
LMIC library is LoraWAN compatible. This demo include: How to use Lora Shield to set up single channel gateway for TTN network. How to use Lora Shield to set up a Lora Node. How is the communication between the Lora Node and Lora Gateway. The full instruction is in this link: [1]
Example2 -- Use the RadioHead Library With Arduino Boards
The RadioHead Library simplifies communication between the Arduino Board and the Lora Shield.We can find it here: http://www.airspayce.com/mikem/arduino/RadioHead/ To use it in your project you just have to copy it in your Arduino project folder (next to your main Arduino project file .ino).After putting the lIbrary in the right place, you have to also modify the frequency to the frequency you want to use, the position of this is setFrequency() in the file: arduino-xxx\libraries\RadioHead\RH_RF95.cpp; Then ,we can easily to use it to do some experimentation.
RadioHead Examples
In this example,we use two Lora Shields to transmit and receive signal,there are some project in the RadioHead Library,the operation is as follows: Connect two Lora Shields with Arduino board and connect them to computer via the USB cable; We used the Lora Shield+Arduino UNO as the server to transmit signal and the Lora Shield+Aduino MEGA2560 as the client to receive signal here.
Lora Shields and Arduino boards Connect the Lora Shield and Arduino,and connect them to computer.
Connection
Open the IDE and choose the right example;
Choose the example
Configure the IDE settings and upload the two skteches to Aduino.
Configure the IDE settings of MEGA
Configure the IDE settings of UNO After configure the IDE settings,upload the skteche to Aduino.Check the Serial Moniter and we can view the running result of the two boards.
Running result of MEGA
Running result of UNO
Usage Notice
You have to be aware that Radio link quality and performances are highly dependent of environment. Better performances can be reached with: Outdoor environment. No obstacles. No high level radio interferer in the ISM 868MHz band. At least 1 meter above the ground.
Radio performances are degraded with: Obstacles: buildings, trees... Inner buildings environments. High ISM 868MHz band usage by other technologies. Radio communication are usually killed with bad topographic conditions. It is usually not possible to communicate through a hill, even very small.
Order Infomation
Lora Shield 868: Load with RFM95W-868S2, support 868M frenquency Lora Shield 915: Load with RFM95W-915S2, support 915M frenquency Lora Shield 433: Load with RFM98W-433S2, support 433M frenquency
Schematic
Lora Shield Schematic Frequent Ask Questions (FAQs)
I have order Lora Shield v95-868, while the chip on lora shield shows RF96? The Lora Shield v95-868 is equied with HopeRF RFM95W-868-S2. This module has a mark RF96 on it. it doesn't mean the chip is RFM96w, but it means the chip is using the SX1276 chip. Mean While, The Lora Shield v95-915 S2 with mark RF96 on the IC. The Lora Shield v98-433 S2 with mark RF98 on the IC and use the sx1278 chip.
