MPR121 touch sensor module
Revision as of 06:03, 30 July 2014 by Admin (talk | contribs) (Interface Connecting and Setting)
Jump to: navigation, search
Media:Arduino-1.0.1.zip
data Source
Media:MPR121.pdf
Media:SI5902DC.pdf
Interface
Interface specifications
Common IRQ: when MPR121 communicates with a 3.3v or 5v CPU, it will send signals to the master control. The IRQ provides input when connected with a periphery controller.
3.3v CLK/ DATA pins: for IIC communication when connected to a 5v CPU.
CND: for ground
MPR121 touch sensor module can be connected and communicate with PCB whose operating voltage can be both 3.3v and 5v. As mentioned above, the connection method varies when connecting to different PCBs with different operating voltage. Here we set it as an example to connect it with Mega 2560.
Get Started
1)Connect MPR121 to Mega2560 with a USB cable, if the LED lights, the connection is ok, as in the following picture.
2)Connect MPR121 touch sensor module with Mega 2560 in light of 3-1
3)Open the test code file mpr121.ino with Arduino1.0.1, you are now in the interface as below:
4)Select the type of board: Tools—Board—Arduino Mega 2560 or Mega ADK.
5)Choose the serial port under use: Tools—Serial Port—COM.
6)Click Button2.jpg to upload program. When Arduino1.0.1 shows an interface as below, the uploading completed.
7)Open serial monitor in Arduino1.0.1, Tools—Serial Monitor. The following windows will pop-up.
8)Press or release the touch button, if the Serial Monitor of Arduino1.0.1 will give response correspondingly, the MPR121 touch sensor module works.
FAQS
1. The MPR121 touch sensor module can’t communicate with 3.3v CPU.
Check if you have connected them rightly. You can refer to picture2-1 and chapter 3.3.
2. The MPR121 touch sensor module can’t communicate with 5 V CPU.
