Tiny210
Revision as of 07:42, 23 February 2012 by Admin (talk | contribs) (Tiny210Mother board)
Jump to: navigation, search
  • 1GHz Samsung S5PV210 with PowerVR SGX540 graphics engine
  • 512MB DDR2 RAM and 1GB NAND Flash
  • LCD/Touch Screen, HDMI,TV out, Audio support
  • TF card, USB Host/OTG support
  • Ethernet, WiFi, serial port, GPIO
  • Contain CPU board
  • Linux 2.6.35 & Android 2.3 support
CPU board Hardware info
Multi-IO:
  • 2 x 60 Pin 2.0mm space DIP connector
  • 1 x 30 Pin 2.0mm space DIP connector
  • 1 x 51 Pin 1.0mm space SMD connector
on Board: HDMI interface 4 x User Leds(Green) 1 x Power Led(Red)
Supply Voltage from 2V to 6V Mechanical: Dimension: 64x 50x 11mm Software: Android 4.0, Android 2.3, Linux 2.6.35, Qtopia-2.2.0/Qt-4.4.3/Qt-4.7
Tiny210Mother board
  1. Integrated USB 2.0 Hub: Extended 4 USB host ports, three of them as the standard side port,and one was lead by SCON interface
  2. AV CCD Camera In: Integrated TVP5150 video chip: 2 AV input port (RCA), can be directlyconnected using a CCD camera
  3. RS485: 1 RS485 interface
  4. Serial Port: 4 serial port, two of them have been converted to RS232, and leads through the
DB9 Block (COM0, COM1), through the CON1, 2, 3, 4, Block leads to TTL level
  1. keys: 8 key
  2. RJ45 Ethernet port: using DM9000AEP, 10/100M adaptive
  3. Audio input and output: using the WM8960 professional audio chip, containing Class D amplifier on-board microphone, and supports HDMI audio and video synchronization output
  4. USB Slave: 1 Road, the USB 2.0 specification
  5. Infrared receiver: 1
  6. ADC input: 6 ADC input
  7. Buzzer: 1, control by the PWM0
  8. EEPROM:AT24C08 (256 Byte) for I2C test
  9. LCD Interface: 2 LCD interface, both 40 Pin 0.5mm Pitch Chip Block, support 3.5 "-19" fullcolor TFT display LCD
  10. SDIO interface: used to connect the SDWiFi module and other
  11. CMOS Camera interface: used to connect CMOS camera
  12. RTC clock: with a backup battery (according to different regions or time periods, mailing may remove the battery)
  13. PCB layer: 2
  14. PCB size: 180 x 130mm, can be easily fixed all kinds of LCD modules, especially the 7-inch LCD module
  15. Power supply: DC-5V
