Arduino DUE
Revision as of 06:26, 29 April 2013 by Admin (talk | contribs)
Jump to: navigation, search
Note:The program will not run until you press the key of reset when you fire program for the DUE from Native USB Port in frist everytime.
  • Microcontroller: AT91SAM3X8E
  • Operating Voltage: 3.3V
  • Recommended Input Voltage: 7-12V
  • Min-Max Input Voltage: 6-20V
  • Digital I/O Pins: 54 (of which 12 provide PWM output)
  • Analog Input Pins: 12
  • Analog Outputs Pins: 2
  • Total DC Output Current on all I/O lines: 130 mA
  • DC Current for 3.3V Pin: 800 mA
  • DC Current for 5V Pin: 800 mA
  • Flash Memory: 512 KB all available for the user applications
  • SRAM: 96 KB (two banks: 64KB and 32KB)
  • Clock Speed: 84 MHz
Documents:
http://arduino.cc/en/uploads/Main/arduino-Due-schematic.pdf Schematic:
