Arduino DUE
Revision as of 09:02, 27 April 2013 by Admin (talk | contribs)
Jump to: navigation, search
 The command set for the module is entirely comprised of ASCII-based printable characters and allows you to change languages (English or Spanish), change between 9 different voices, and even control speech parameters on the fly. The module also communicates back to your system so you can get settings, version information and even "finished speaking" flags back from the board.
