Geeetech M1 3D printer
Contents
[hide]- 1 Printer Introduction
- 2 Printer Maintenance
- 2.1 How to clean the hotend
- 2.2 How to Replace the hotend
- 2.3 How to replace the nozzle
- 2.4 How to Replace the Control Board
- 2.5 How to Replace the Screen
- 2.6 How to Replace the Extruder
- 2.7 How to Automatically Level
- 2.8 How to Manually Level
- 2.9 How to adjust the X-axis belt
- 2.10 How to remove the upper frame
- 2.11 Mainboard wiring diagram
- 2.12 Print head adapter board wiring diagram
- 2.13 How to install the 1KG filament holder
- 3 Trouble Shooting
- 3.1 Black Screen
- 3.2 Update Firmware
- 3.3 Minimum Temperature Error
- 3.4 Filament cannot be extruded
- 3.5 Model does not stick to the platform
- 3.6 Print file is not displayed
- 3.7 Abnormal temperature during automatic leveling
- 3.8 Printing continues after the material break detection alarm
- 3.9 How to Import Profiles into Cura
- 3.10 How to import configuration files into Orcaslicer
- 3.11 The consumables don't stick to the hot bed
- 3.12 The print is brushed or leaked
- 3.13 Underextrusion and overextrusion
- 3.14 The top-level seal is insufficient
- 3.15 Print offset
- 3.16 Surface spots and stripes problems
- 3.17 There are gaps between the edge and the filling
- 3.18 Rough edges and corners
- 3.19 Top layer surface scratch problem
- 3.20 Holare holes in the bottom of the corner linet
- 3.21 The side edges are uneven
- 3.22 How to print PLA
- 3.23 How to print TPU
Appearance
Main specifications
Printer type: FDM
Layer thickness: 0.1-0.2 mm
Automatic leveling: Yes
Breakpoint resume: Yes
Nozzle diameter: 0.4 mm
Printing accuracy: ±0.1 mm
Ambient temperature: 10-40 ℃
Power Input:
Net Weight(kg): 3 kg
Gross Weight(kg): 4 kg
M1 1KG consumables installation video
Download link of M1 1KG fliament model file
Black Screen
3、 The printer is blocked
Solution:
(2) Click Import
(3) Click Import Configs...
4、 Click Yes for all
3.The extruder is not working
How to print PLA
Nozzle temperature: 190-210℃
Bed temperature: 30-60℃
Fan Cooling: 100%
Nozzle temperature: 220-240℃
Fan Cooling: 100%
