1602 LCD
Jump to: navigation, search
General Description
  • 16 characters (5x8 dots) x 2 lines FSTN Positive Black & White Transflective Dot Matrix LCD module.
  • Viewing Angle: 6 O¡¯clock direction.
  • Driving scheme: 1/16 Duty, 1/5 bias.
  • HD44780 LCD Controller and Driver or equivalent.
  • 40-Channel Segment/Common Driver for Dot Matrix LCD or equivalent.
  • Connector: 16 pins ZIF SMD connector (CON-IL-402).
  • White LED05 backlight.
description
wiring diagram
example
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
void setup() {
 // set up the LCD's number of columns and rows:
 lcd.begin(16, 2);
 // Print a message to the LCD.
 lcd.print("hello, world!");
void loop() {
 // set the cursor to column 0, line 1
 // (note: line 1 is the second row, since counting begins with 0):
 lcd.setCursor(0, 1);
 // print the number of seconds since reset:
 lcd.print(millis()/1000);
Click here to buy 1602LCD
