color mixer
pawien
color mixer
Post by pawien » Thu Dec 19, 2019 11:13 pm
HI
I wanted to use the color mixer software for 3 exdruters.
Software does not work with 3
Re: color mixer
Post by William » Fri Dec 20, 2019 9:28 am
Hi, You can use color mixer for color mixing,
Or use the on-screen color mixing ratio to set it.
You can refer to this about the use of color mixer: viewtopic.php?f=92&t=69600
pawien
Re: color mixer
Post by pawien » Fri Dec 20, 2019 5:29 pm
HI
If I import the gcode then change color gradient and go to mixing the program closes
Re: color mixer
Post by William » Fri Dec 20, 2019 5:47 pm
Hi,If this is the case, you may have problems with your slices or you can try running in administrator mode;
You can also download it again, maybe the wrong characters in the storage path cause this to happen.
pawien
Re: color mixer
Post by pawien » Fri Dec 20, 2019 9:27 pm
Hi there
With Repetier host ...... works
With Simplify ............... does not work
sneazzy95
Re: color mixer
Post by sneazzy95 » Sat Dec 21, 2019 12:24 am
Hello, thanks for the answer
I'll try with the Repetier host.
Appvalley TutuApp Tweakbox
Users browsing this forum: No registered users and 17 guests
