3D Touch help needed
Da9L
Post by Da9L » Tue Oct 01, 2019 6:02 pm
I have a Geeetech I3 Pro B, and as an upgrade i wanted to install a 3D Touch sensor. And so i've done, and it is working pretty good it seems. BUT i noticed that the needle of the 3D Touch sensor is not retracted while printing, resulting in the needle being the same height as the nozzle. This then causes the needle to sometimes hit the print, which is not optimal ofcourse. Can i somehow make the needle retract before the print starts?
Re: 3D Touch help needed
Post by William » Mon Oct 07, 2019 9:24 am
Hi, If you are referring to the fact that the pointer does not retract,
you can try to adjust the screw on the 3d touch, which may be too tight.
I hope this can help you.
