Cura json file for your Geeetech A10M printer
Moderator: vert
LisaE
Re: Cura json file for your Geeetech A10M printer
Post by LisaE » Mon Apr 29, 2019 4:54 pm
Honestly, I don't understand the script. In the comments it says "all used Extruder", but in the commands T0 is hardcoded. I only know Cura so far, but there are different tools with different Tx names, i.e. T0 to T7.
I don't understand the meaning of a script like that either, if I'm honest. In Cura the start code is inserted behind the temperature settings of the slicer. Even if the script would insert the current temperatures for bed and material, it would at best double the temperature assignments. In the worst case, it will cause the temperature assignments to be wrong.
It may be that other slicers work differently and it makes sense. As I said, I'm not familiar with that yet, I've only been working with 3D printing for a few weeks. But I don't think it makes any sense in a Cura profile.
Post by _kaktus_ » Tue Apr 30, 2019 12:13 am
Hi.
:mrgreen:
Don't worry about it. ;)
This is just an example of how a script can be made more universal. Of course it may not be compatible with every Slicer.
And as you've noticed, this script is not perfect. :D
LisaE
Post by LisaE » Tue Apr 30, 2019 11:28 pm
OK, got it :D
To be honest, I find the collaboration between Cura and the A10M somewhat sobering.
However, I also understand Cura's position, who doesn't want to spend money on a development that supports cheaper hardware from the competitors.
But no matter, I'm doing my own postprocessing script now. At least I know what it does, even if not everything will be perfect in the beginning :D
Post by _kaktus_ » Tue Apr 30, 2019 11:49 pm
mariusvr
Post by mariusvr » Sat Feb 08, 2020 1:57 pm
Can we please make this post visible somewhere central as it also has other printer profiles in it (Like my A30M).
After applying the profiles the print quality is AMAZING and only found this post by chance.
Thanks, Marius
Users browsing this forum: No registered users and 15 guests
