How to burn the firmware for GTM32 Pro VB
Re: How to burn the firmware for GTM32 Pro VB
Post by William » Fri Nov 30, 2018 11:09 am
jonatan wrote:
Fri Nov 30, 2018 11:05 am
no entiendo el punto 2.2 Inserte una tapa de puente correspondiente en el arranque0 de la placa.
me podria explicar mejor? no entiendo que ahi que hacer.
tengo este error
Burn the bootloader and then upload the firmware.
Then you need to install the drivers for this board,set the baud rate to 115200
Post by _kaktus_ » Fri Nov 30, 2018 1:14 pm
Hi.
:mrgreen:
Do you know what a jumper cap is?
jonatan
Post by jonatan » Sat Dec 01, 2018 3:34 am
no tengo idea de que es o que ahi que hacer ?
jonatan
Post by jonatan » Sat Dec 01, 2018 3:49 am
ahi que sacar ese cosito negro que sale señalado en la foto ?
jonatan
Post by jonatan » Sat Dec 01, 2018 3:55 am
o ahi que ponerle algo ahi? donde lo consigo ? no se nada de esto !
jonatan
Post by jonatan » Sun Dec 02, 2018 3:41 am
hola he echo los pasos que dice en el foro, y ahora no me anda el lcd y el ventilador del extrusor.
que pudo aver pasado ?
hitmano
Post by hitmano » Wed Mar 27, 2019 3:51 am
It would be extraordinary if these two open source sheets could bolster Marlin 2.x 32bit rendition. I have no clue about coding. However, this would be amazing if Geeetech or clients who can code would make Marlin 2.x to be good with the GTM32 sheets. So much conceivable outcomes and highlights would open up for the clients and furthermore for Marlin. I've seen this issue posted on the Smartto firmware store which as I would see it would have a place here, it's anything but a firmware issue/highlight however increasingly like an equipment issue.
Locked
