SD Card Problem
DoubleK
SD Card Problem
Post by DoubleK » Sun Jan 15, 2017 4:41 pm
Hi my problem is that i cannot print from sd card without computer. On the panel i see the file, after enter the display shows me it is printig but it do nothing. I have a sandisc sdhc 4gb card. Is this the problem from the sd card or is the problem the sd card reader?
bang
Re: SD Card Problem
Post by bang » Wed Jan 18, 2017 11:59 am
I guess it is the SD card...
All the .gcode files in the card have the same problem?
Did the bed and extruder heat up after you clicked on the file?
DoubleK
Re: SD Card Problem
Post by DoubleK » Wed Jan 18, 2017 11:22 pm
No the bed and the extruder did not heat after i start the print job
bang
Re: SD Card Problem
Post by bang » Thu Jan 19, 2017 5:57 pm
DoubleK wrote:No the bed and the extruder did not heat after i start the print job
So all of your files in the card had the same results?
Did you check the gcode of the problematic file?
Was it OK?
DoubleK
Re: SD Card Problem
Post by DoubleK » Fri Jan 20, 2017 1:24 am
Found the failure, i saved the files on the sd card with binaryformat for repetier firmware and then printer say wait for user and do nothing. I must disable this option and then it works.But when the printjob is longer as 2 hours it stopped without no message . Post can be closed, thank you.
Users browsing this forum: No registered users and 9 guests
