extruder overheating
ant311
Post by ant311 » Sat Apr 30, 2016 3:01 am
hi all. my i3 pro b's extruder seems to be overheating, the thermistor seems to be working fine, but keep getting a m999 error, the lcd and software both show the set temp and the temp of the extruder,
is this a board fail or firmware ?
could someone please help thanks
Re: extruder overheating
Post by Mark » Sat Apr 30, 2016 3:33 pm
Did you see any MAX/MIN temp error on the LCD? I think you need to check this link to check the mainboard and thermistors:
http://www.geeetech.com/forum/viewtopic ... 23&t=17030
ant311
Post by ant311 » Sat Apr 30, 2016 7:13 pm
I did, max temp message on lcd ,
Admin
Post by Admin » Fri May 06, 2016 5:27 pm
did you check the solder or the thermistor?
please upload some pohotos
ant311
Post by ant311 » Mon May 16, 2016 5:21 am
All sorted the thermistor was at fault
Admin
Post by Admin » Mon May 16, 2016 10:29 am
if so, you can buy a thermistor at your local store or contact the after sale service to send you the replacement
