Firmware for geeetech 3D printers
Nils
Re: Firmware for geeetech 3D printers
Post by Nils » Wed Jun 12, 2019 2:31 am
vert wrote:
Tue Jun 11, 2019 10:58 am
Nils wrote:
Mon Jun 10, 2019 10:48 pm
Hello.
In the firmware for the I3 Pro B there is an error so that I can not upload the file to my printer. I use the Arduino software version 1.8.5
Would it be possible that one cares about this issue and informs me as soon as the firmware goes again?
Error code :
exit status 1
using typedef-name 'fpos_t' after 'struct'
The error is in the SdBaseFile.h file
looks like a version incompatibility error
what version of marlin is it as arduino 1.8.5 works with 1.1.8 but not older marlin.
I downloaded an older version of Arduino and that was it. So the firmware versions of the I3 Pro B which are in the forum above are not compatible with the current version of Arduino. Maybe someone can update the firmware to match the current Arduino software
vert
Post by vert » Wed Jun 12, 2019 8:48 am
Hello.
Error code :
exit status 1
nobody works on the old firmware anymore its been unsupported for a long time try using marlin 2.0 if you want the current version of marlin as well as arduino.
Marlin 2.0 For Geeetech 3D Printers
My YouTube
My GitHub
My thingiverse
My Discord
The 3Dprinting hobby isn't a door you open, it's a path you walk as you learn.\
Being hostile is the best way to not get assistance.
True knowledge is being able to teach others.
sundogz
Post by sundogz » Thu Jun 13, 2019 11:31 pm
I have one of the first Acrylic I3 ProB printers and my hotend now heats 35-40 degrees higher that it's set for. I've changed thermistors twice with no joy - so swapped boards thinking it was the firmware. But the the problem with hotend is still there, and the new board must be for the T8 rods (mine has the M10's) - the Z just crawls a couple inches and stops. I don't know how to set it - the LCD 'load' and 'save' features reset after power down.
Do you have the old version of firmware available or can tell me how to check set this. I have gone over the Arduino thread but guess I am not smart enough. :shock: I use this printer every day and miss it. I hope you can help
TribunXy
Post by TribunXy » Mon Jul 01, 2019 2:52 pm
is it possible to get Marlin 1.1.9 for the Pro W? Or at least a list of the values ​​that have to be changed in the original firmware?
Post by _kaktus_ » Thu Jul 04, 2019 11:51 pm
lauraroz wrote:
Thu Jul 04, 2019 5:04 pm
A mi me vino genial para impresión 3d para regalos de comunión para niños
Admin wrote:
Tue Aug 28, 2018 5:59 pm
Hi,guys!
In order to create a more comfortable discussion environment for forum members.
We have to make some rules,
  1. Mutual respect. Every member should respect each other, which is a prerequisite for mutual discussion. This is like a "mirror". If you don't respect others, we can only tell you with regret: Please leaves this forum!
  2. This forum brings together members from all over the world, so be kind and write in English. This will make it much simpler and easier to search the content.
    Admin 2018-08-26
    Update: 2019-03-02
Marcellus
Post by Marcellus » Wed Jul 10, 2019 3:31 pm
Hello
Please tell us when a new firmware will be released (Geeetech A30) ?!?
Greets
Post by William » Wed Jul 10, 2019 3:42 pm
Thanks for your feedback.
vincentbcd
Post by vincentbcd » Wed Jul 31, 2019 10:38 pm
I surch a firmware for my I3 all aluminium, with GT2560a+, DRV8825,and LCD upper, bed heater aluminium, please.
Do i install firmware with arduino 1.0.1 or can i install it with better, if yes, wich one?
It's the same frame of this.
https://www.geeetech.com/geeetech-prusa ... p-944.html
Thanks a lot for you helping.
Post by William » Thu Aug 01, 2019 9:20 am
Hi, you can refer to this download:http://www.geeetech.com/forum/viewtopic ... 20&t=17046
I hope this can help you.
vincentbcd
Post by vincentbcd » Thu Aug 01, 2019 11:39 am
Thanks William, i heve ever view that, i would day if i can take Arduino younger than 1.0.1.
Locked
