A10M Profile for Simlify3D
Share your configuration profile, please specify your printer model and the slicer software.
3D by EB
Re: A10M Profile for Simlify3D
Post by 3D by EB » Sat Feb 02, 2019 11:36 am
O.k. I finally have the stringing fixed.
Recalibrated the extruders to about 400 pulses per mm.
Loosened the extruder tension all the way and then tightened back 2.5 turns.
The biggest improvement came with changing out the bowden tube fittings on the extruders. The stock fittings were not holding the tube tight enough causing erratic retraction.
Big tip that I had to find out the hard way. The boden tubes on this machine have an O.D. of almost exactly 4mm. I replaced them with ones from my CR10S. I had massive jamming for almost a week until I realized that the tubes I installed were aprox 4.15mm and were too large to seat in the hot end. The boden tubes on this machine have to be fully inserted almost 50mm.
Attached is the FFF that I am currently using.
Geeetech A10M 3d by EB V2.zip
(3.17 KiB) Downloaded 724 times
3D by EB
Post by 3D by EB » Sun Feb 03, 2019 5:55 am
Woops... I made a typo on the retraction and wipe settings. I set the primary extruder too high.
Here is the update without the mistake.
Geeetech A10M 3d by EB V3.zip
(3.16 KiB) Downloaded 816 times
Post by _kaktus_ » Sun Feb 03, 2019 3:48 pm
Hi.
Thank you on behalf of all concerned.
3D by EB
Post by 3D by EB » Mon Feb 04, 2019 9:11 pm
You are all very welcome!
I'm glad to help.
maglioni
Post by maglioni » Wed Feb 13, 2019 11:29 am
This ought to work for the A20m except for the print dimensions, right?
3D by EB
Post by 3D by EB » Mon Feb 18, 2019 4:07 am
It should work after you change the dimensions.
I just found out that this profile isn't flagged properly as a dual color profile in simplify3d.
I have fixed that in my current version.
I'm at Gallifrey one convention in Los Angeles right now.
I'll post it as soon as I get back home Tuesday.
Post by William » Mon Feb 18, 2019 9:41 am
Cool!It seems pretty good.
primeraimpresion3d
Post by primeraimpresion3d » Tue Feb 26, 2019 7:09 am
your slow print profile served a lot since I did not know what to do with the printer. If there was a profile for the double extruder it would be great. Have a nice day
3D by EB
Post by 3D by EB » Wed Feb 27, 2019 6:48 am
Sorry for the late reply. I wanted to make sure the profile was as good as I could get.
I have attached 2 profiles, a standard one and one for if you have a touch sensor installed.
Both profiles now work with Simplify3d dual extrusion wizard.
**Touch Sensor profile only**
The touch sensor profile has a complex start script.
It keeps the head at a max of 150 degrees so that the nozzle doesn't leak while it is doing the 9 point bed level.
If you need to change extruder temp with the Touch sensor profile, you will have to change the start script line
"M109 S195 ; Set extruder temp and wait to be reached" The number after the S is your extruder temp
Geeetech A10M 3D by EB V5.zip
(3.41 KiB) Downloaded 833 times
Geeetech A10M 3D by EB V5 Touch Sensor.zip
(3.54 KiB) Downloaded 848 times
primeraimpresion3d
Post by primeraimpresion3d » Wed Feb 27, 2019 11:21 am
thank you very much friend. Sorry for the translations. Every day I look at the forum because your profiles make the printer work perfectly. I will try it today. thanks again for the contribution.
